UrS4 2.2T Avant project
  • prj
    • Mar 2010
    • 6308
    Can be spark missing also, the dwell is quite conservative in your tune, the coils just might need more dwell.
    • Thuppu
      • 4115
      Ok. Little too much on rich side and some boost, propably the coils just havn't the needed juice to ignite the mix. That could be the cause for the cutouts. But have to resolve why it's suddenly runns richer... can't be the fuel. Have to check the timings so the belt hasn't jumped a tooth.
      • prj
        • Mar 2010
        • 6308
        It can also run richer if your current setup breathes worse than your previous setup.
        Also, if you changed the amount of boost it gets, that can change how it runs as well.
        I usually make the areas that were not mapped for pig rich, so that if something happens for some reason and the boost goes where it shouldn't he engine does not blow up.
        • Thuppu
          • 4115
          The fact that it has gone richer and richer with same setup can sure be that it's have been on different boost level when I have been testing. Another thing can be the cat, if it has start to molten and has clogged up..? I'll guess it affects the engine flow... Ex temps arn't high so this will propably not be the problem. Have to check it anyway.
          • Isaksa
            • Oct 2013
            • 64
            • Country: Norway
            #1100
            Does the knocksensor trigger the CE light?
            Mine Urs4 also light up the check engine light for 1-2 seconds after a drag..
            No faultcode stored.
            • Thuppu
              • 4115
              Havn't had any time for the car, but I propably figured out why it's running richer and why I got cutouts. It started to do that badly on the trackday. The wastegate doesn't work. It's maybe the turbosmart controller or the wg itself. I screw the controller to zero and it's still boosting over 2bar. Can't say how much because my boost gauge only shows 2bar, the needle goes to ~2,2bar. LOL, maybe it boost something like 3+bar, no wonder why the small hose popped off the ecu, and why it cuts... it also explains why it run pig rich, if it's using a total wrong area of the map.
              Have to connect back the N75 and see. If it's not helping then the WG has seized or the diaphragm is broken. Good thing is that the head gasket have held out nicely and the IM havn't exploded.
              • diesel des
                • 3896
                #1102
                Cool lol
                Sent from my GT-N7105 using Tapatalk
                • prj
                  • Mar 2010
                  • 6308
                  And that's exactly the reason why I map the unvisited/unmapped areas pig rich with late timing.
                  This is the reason why you still have the engine in one piece.
                  • Acki
                    • Mar 2014
                    • 302
                    Nice vehicle Trackday with the Girling brake and 600hp works?! Really?
                    • diesel des
                      • 3896
                      #1105
                      Also shows how strong the holset turbos are.
                      • Laaf
                        • Oct 2010
                        • 275
                        Time to step up and buy a more manly boost gauge
                        • prj
                          • Mar 2010
                          • 6308
                          Yes, gauge for man boost is a good idea.
                          As for holset turbos - everyone this side of the world runs them, and I mean everyone.
                          Compared to Garrett they are nigh indestructible.
                          • Thuppu
                            • 4115
                            This would be a nice gauge http://www.demon-tweeks.co.uk/motors...bo-boost-gauge
                            In diesel applications they boost up to 3-5 bar with Holsets.
                            • Thuppu
                              • 4115
                              Something like 2 euro fail. Too soft hose used, need to have some braiding...
                              The IM seemed that is has had difficulties to hold against the pressure. Would be fun to know how big the pressure has been..?
                              • Thuppu
                                • 4115
                                Nothing fancy happend here. Got the 3bar boost gauge. Shouldn't bee any trouble to read it, even without glasses, it's sure big enough. Only have trouble to decide where to fit it..? Really nice and friendly custom service at JJC race and rally where I ordered it from. Had to change one item in the order, and they didn't even bill mee of the extra £10 what the other item was.
                                Got also a kit of wheel studs. Easier to fit different size spacers if wanted, and faster to change the wheels. Fitted the studs with some Locktite.
