Good job. Are you all done with a reserve!
UrS4 2.2T Avant project
The fuel delivery system starts to take form...
Yet have to do a chassis plate for the setup, isolated with rubber mounts.
BMW 740iA e38 - ProjectComment
This is complete overkill unless you plan to run it on E85...
I hope the FPR will manage to hold the 4 bar fuel pressure.Comment
In the future I hope to run E85, but we don't have it here yet so will go with 98/99 octane for now. I don't want to move a finger anymore because of the fuel system.
Many in Finland has used the Mallory 4305M FPR without problems, and also with big power Audi projects.
What size wire should I use for the electric feed?
I'm not sure what you mean, but if you ment the oil cooler fittings they are normal industrial fittings with braided teflon hose. If I remember right the thread size on the oilfilter housing(and adapters) was M18x1,5. You can have them made in a local hydraulic store/workshop.
Edit.
Still have to make a bridge between the pumps, like the 034 style:
Ok, you mean the turbo oil feed. Did found the adapter for it also from the hydraulics store. Don't remember the threadsize though.
Any day now... will the engine start... I hope.
Made a assembly plate for the pumps and got also the fuel bridge done(needs only the thread for the fuel line adapter). Don't ask how I did the fuel bridge out of a 30x500x1000mm plate...
Tools that was used... angle grinde, belt grinder and a bench drill.
Intake pipings are done. By-pass and N75 inlets. ISV outlet and watermist nozzles etc...
nice use of outu kumpu pipework!!...
can you make me one?.....
c'mon Thomas, don't be shy....get it started.....:mischeif:Comment
nice work Thuppu
