UrS4 2.2T Avant project
  • Melber
    • May 2009
    • 36
    • Country: Russian Federation
    #511
    Good job. Are you all done with a reserve!
      Are you going to do anything to promote air flow to the cooler at that angle?
      • Thuppu
        • 4115
        Yea, have to do some kind of air guides from the bumper inlet.
        • Thuppu
          • 4115
          The fuel delivery system starts to take form...
          Yet have to do a chassis plate for the setup, isolated with rubber mounts.
          • prj
            • Mar 2010
            • 6308
            This is complete overkill unless you plan to run it on E85...
            I hope the FPR will manage to hold the 4 bar fuel pressure.
            • Thuppu
              • 4115
              In the future I hope to run E85, but we don't have it here yet so will go with 98/99 octane for now. I don't want to move a finger anymore because of the fuel system. Many in Finland has used the Mallory 4305M FPR without problems, and also with big power Audi projects.
              What size wire should I use for the electric feed?
              • Prosac
                • 108
                Hello. I'm most rebuilt.
                Can you tell me which oil adapter you've taken? I find nothing what suits me.
                408kw @ wheel
                  Good work overkill is good rather have the ability to pump more fuel than the engine can use than too little
                  • Wrath
                    • Jan 2011
                    • 779
                    Totally agree nice work Thuppu
                    1995 Audi S6 - AAN (~350hp)
                    2008 BMW 530xd (235hp)
                    2011 KTM 990 SMR - custom tuned (120whp)
                    • Thuppu
                      • 4115
                      I'm not sure what you mean, but if you ment the oil cooler fittings they are normal industrial fittings with braided teflon hose. If I remember right the thread size on the oilfilter housing(and adapters) was M18x1,5. You can have them made in a local hydraulic store/workshop.
                      Edit.
                      Still have to make a bridge between the pumps, like the 034 style:
                      • Prosac
                        • 108
                        Ok Thanks. I have also a hx40s of kkd motorsport. search for an oilladapter on the garrett gt oil pipeline.
                        408kw @ wheel
                        • Thuppu
                          • 4115
                          Ok, you mean the turbo oil feed. Did found the adapter for it also from the hydraulics store. Don't remember the threadsize though.
                          • Thuppu
                            • 4115
                            Any day now... will the engine start... I hope.
                            Made a assembly plate for the pumps and got also the fuel bridge done(needs only the thread for the fuel line adapter). Don't ask how I did the fuel bridge out of a 30x500x1000mm plate... Tools that was used... angle grinde, belt grinder and a bench drill.
                            Intake pipings are done. By-pass and N75 inlets. ISV outlet and watermist nozzles etc...
                            • europeanme
                              • Oct 2005
                              • 3817
                              nice use of outu kumpu pipework!!...
                              can you make me one?.....
                              c'mon Thomas, don't be shy....get it started.....:mischeif:
                              • Carfreak
                                • Apr 2012
                                • 225
                                Awesome!!! Also want one of that intake piping
