UrS4 2.2T Avant project
  • so that's 2 left and 2 right?
    • Originally posted by quattrostyle View Post
      now theres a thought.....:mischeif:
      • Well, in my opinion dual twins are too much bimmer look.
        Edit. Hmm, ~50km to the nearest E85 fuel station. What size injectors would be enough to max out the HX40S with E85?
        • Originally posted by Thuppu View Post
          good point!!....stick with the twin 3" tailpipes...
          • Well, it's very theoretically but let's have a go.
            - 700hp capable turbo, that's at least 0,6kg/s airflow.
            - Burning air to fuel at a ratio of 10 with E85 mixture with density of 780kg/m³ would need around 4500cc's per minute, divided over 5 cylinders is 900cc/min injector MINIMUM.
            - Max mapping DC of 80% to have enrichment margin, make it 1200cc/min flow.
            Of course a smaller injector could do combined with increased pressure delta over in injector by tweaking the FPR.
            • Ok, thanks for the theory. My EV14 does 1000cc@4bar, so they are pretty close...
              • We all like the beemer look, or S8 look
                1995 Audi S6 - AAN (~350hp)
                2008 BMW 530xd (235hp)
                2011 KTM 990 SMR - custom tuned (120whp)
                • Originally posted by Wrath View Post
                  Do you have more pictures of this car?
                  • Originally posted by Topolini View Post
                    Here is Wrath's project thread: http://www.s2forum.com/forum/showthread.php?t=57461
                      Thank you!
                      • Exhaust still not finished but drove it today. My neighbours propably love mee.
                        Looks quite sharp in the image, but there is much rusty and rotten places on this car. I sure you that better ones has been broken to parts many times.
                        • Rusty or not it still looks great!
                          96 S2 aby Coupe. Rebuild Project
                          96 mk3 golf tdi daily.
                          • yeah, looks good. Has a nice stance.
                            • Looking even better when you know what´s under the bonnet
                              Fiat 131 Abarth replica AAN
                              • Thanks guys.
                                Collected all info about the technics, mods etc. so far.
                                Block:
                                - 82,5mm bored stock AAN block
                                - Pauter rods
                                - JE-pistons 82,5mm 8,5:1 CR
                                - CP lightweight 20mm piston pin's
                                - APR(replica) studs
                                - Machined water jacket
                                - 25-row oil cooler
                                - Engine mounts alu polyurethane(made by AnLe audifinns)
                                - Engine front mount 034 polyurethane/DIY
                                - DIY sump baffles
                                Head:
                                - Cams 7A exhaust cam, AAN cutted ex cam as intake cam
                                - Rosten high load springs and bottom retainers
                                - Stock INA lifters
                                - Lightly ported head
                                - Re-shaped ex- and intake valves
                                - Rosten adjustable ex cam gear and intake cam sprocket
                                Breathing:
                                - Tube exhaust DIY
                                - AAN intake manifold
                                - Tial MVR wastegate
                                - Holset HX40 Super Turbo
                                - 4" Downpipe
                                - 5" 100cell catalytic converter
                                - 3,5" Exhaust with Simons silencers
                                - 3" IC piping
                                - 450x300x76 cooler
                                - Aquamist HFS-3 water injection
                                Engine management:
                                - Motronic
                                - RS4 MAF
                                Fuel delivery:
                                - 2 x Bosch 044
                                - 2 x stock fuel filters
                                - Walbro 255LPH lift pump
                                - ~4,8 liter surge tank
                                - Mallory 4305M FPR
                                - 12x1mm fuel piping
                                - 1/2" and 3/8" steel braided teflon lines with pressed hydraulic fittings
                                - Bosch EV14 1000cc@4 bar injectors
                                - Custom "Motorsport" fuel rail
                                - DIY breather system with swirl pot
                                Ignition:
                                - 1.8T/TFSI coils
                                - Bosch F5DP0R plugs
                                - DIY loom
                                Driveline:
                                - SRE pressure plate, 4-puck sinter
                                - Fidanza lightweight alu flywheel
                                - 01E 6-gang gearbox
                                Suspension and brakes
                                - Koni sport shocks
                                - Weitec -40mm springs
                                - Front subframe bushings replaced with DIY alu/steel bushings/mounts
                                - Rear subframe bushings replaced with delrin bushes (made by bambridge S2forum)
                                - Front brakes S4 B5 30x321mm disc's with HP2 calipers
                                - Rear brakes stock
