UrS4 2.2T Avant project
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #796
    I bet he's going to use mafless system ...
    • Thuppu
      • 4115
      Mike, I have been using a MAFless system, since last summer. Works really great, but still need to resolve some issues(not MAF or MAP related). Dmitri was here, and he got the car running quite powerfull...(don't ask him how many times he mapped the car from scratch ) until it lifted the head and blown the heater radiator. We like had a steam bath inside the car with Dmitri.
      • prj
        • Mar 2010
        • 6308
        Yes, started lifting over 2 bar. At 1.8 bar everything was fine, but over that started to lift, even with conservative timing (Gasoline timing on E85).
        Luckily nothing got damaged.
        The car is running speed density, so MAF is no longer needed.
        • jaychen
          • Jun 2013
          • 269
          • Country: Australia
          #799
          What brand h-beam rod are you using?
          • Thuppu
            • 4115
            Pauter(x-beam) ATM, Aronmatic's china rods in the ghetto build.
              Nice one Thomas, I have a bunch of AAN engine parts here if you need something I might have it
              Also I need to measure that washer for you
              • europeanme
                • Oct 2005
                • 3817
                is that the same as JP's car?......
                Thomas, got any spare dairy pipework.....
                • V6quattro
                  • Sep 2008
                  • 949
                  Do you know why the head lifted?
                  1360kg/600Whp Avant 0-200km/h 9sec
                  • Laaf
                    • Oct 2010
                    • 275
                    With the headbolts he used were no instructions inlcluded or anything mentioned from the seller. The bolts didn't get retorqued after first warmup so this is the result. In the end it didn't mean much as the engine was eating alot of oil anyway and that was badly affecting the mapping.
                    • Billman
                      • 4129
                      #805
                      What are the signs you see when the head is lifted? Pressure on the coolant system from the start or something else?
                      Go Holset or Go RS4
                      • Laaf
                        • Oct 2010
                        • 275
                        It lifted from about 2 bar of boost onward. They blew the heater radiator in the cabin when it happened Otherwise when going under, at 1.8 bar as Dmitri said it worked fine, except using lots of oil.
                        The head gasket is scrap and block deck and head will need skimming when this occurs.
                        • prj
                          • Mar 2010
                          • 6308
                          When inside the car is like turkish sauna because the rad blew from the pressure!
                          Or when your coolant light comes on and you realize the expansion tank is empty.
                          • Thuppu
                            • 4115
                            Ok, UrS4 sold and this beast came to replace it. Light car and boosts like sick, really scary to drive!!! I know, a lot of you gona be jealous... sorry guys, not everyone can afford a beast like this.
                            Pic 1.
                            Pic 2.
                                Wicked! lolz
