UrS4 2.2T Avant project
  • prj
    • Mar 2010
    • 6308
    On a UrS4 I have tuned here on gasoline, with standard camshafts and standard head, no methanol injection and 98 RON, we got 350kw at the wheels with 2.3 bar boost to redline. Also HX40 Super.
    • Prosac
      • 108
      350kw at the wheel and original head and camshafts are very good I think. What do you have for exhaust gas temperatures?
      408kw @ wheel
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #918
        490whp?
        So flywheel must be like 580hp?
        • prj
          • Mar 2010
          • 6308
          Peak is around 800C after turbo. After that the ECU floods it. The car runs 11.9 on 1/4 mile, which is not bad considering it's weight.
          But it is not very fast on a long distance, because it floods to 10-10.5 AFR to prevent the engine from melting.
          This season methanol injection and 7A camshafts will be installed, and we will see how it goes.
          • eske
            • May 2010
            • 41
            I had exactly same setup on my urS4 and it did 604hp/758Nm (flywheel). Boost was ~2.1bar.
            11.4 1/4mile and 272kmh 1mile
            And Thuppu, very promising start with that mild level of boost you got.
            • Thuppu
              • 4115
              Quite difficult to tell real ex temps if it measures after the turbo. The sensor should be in the manifold collector or in the beginning of the turbo hot side. That is propably close to 1000C in the mani.
              • Thuppu
                • 4115
                Testfitted the icewheels. Front fitted well with a 2mm clearance, but in the rear I had to grind off a bit of the calipers. Maybe soon it's time to drive on ice.
                • europeanme
                  • Oct 2005
                  • 3817
                  nice one thomas.....you must be thrilled at the results.....
                  • V6quattro
                    • Sep 2008
                    • 949
                    Nice. I wish it was possible to do some ice racing here in Holland
                    1360kg/600Whp Avant 0-200km/h 9sec
                    • Laaf
                      • Oct 2010
                      • 275
                      Do you plan on going to Tahkovuori 7.2-8.2?
                      • Thuppu
                        • 4115
                        Mike, I was really supriced about the output, and yes, it feels good.
                        Lars, no, I'm not going there. It's too far away. Nice to blow the engine and be stuck there.
                        • Henkjan
                          • 1705
                          http://www.deuithof.nl/ijskarten
                          • Laaf
                            • Oct 2010
                            • 275
                            I guess the Frankenstein engine will hold pretty much everything I'm keen on taking the S4 and go have a look on saturday, but I'm attending on that very friday. Guessing that driving for a couple of hours wouldnt be really fun then
                            • Thuppu
                              • 4115
                              New exhaust tip. 2x3,5"
                              • Rocco
                                • Aug 2007
                                • 6393
                                • Country: Spain
                                #930
                                Could not go bigger Tomas?
