Don't know how much the pinns can take, they are 22mm though, and lightened. This kit was made back in 05 and have been laying around in a shelf since that. Got them really cheap. I want ot modify the top, mill off a bit to make higher CR, so I was in contact to Ross and they told I could safely take off 3,7mm of the piston top land. With 155mm rods I would take less, but either way that mean I have to mill off the block also. Have to measure the block before anything, if it's sligly more than 236mm(like 236,6mm or something) then I may go with 159mm rods. That's why I asked this: http://www.s2forum.com/forum/showthread.php?t=68839
I was thinking the squish backwards. Was remember that stock squish is about 0.80mm, and a small squish is good, but I guess it's not a problem with E85..? What I know, engine effiency should be better with tight squish, and it should also bee less knock sensitive.
