UrS4 2.2T Avant project
  • Some pics of the head, combustion chambers are also re-shaped , there is more room around the valves and the casting is smoothen down.
    • Turbo pics. HX40S #16 vs K31 #24. Also refurbed a #20 size tubine housing for it, could be a quite nice size..?
      • Here is also a small diy quick spool valve build, don't know how it will work out..?
        • Very nice Thuppu!!!
          Allways interesting to SEE what is on your mind to do with 5 pot.
          • holy crap,that's a big turbo
            are you going for 1000 hp thomas?
            so the k31 is a twin scroll turbo than?
            which actuator are you going to use for the exhaust valve,electric or with a turbo waste gate actuator maybe?
            TWINCHARGED power,zero lag
            AEM W/M injection
            • Damn,this look good Thomas
              • Good work!
                • You plan on building an AAT block for the urs4 Thomas?
                  Also was that AP racing clutch custom built for the Audi
                  or were they being sold for our cars at some point in time.
                  They make top notch brake products.
                  • Nick, the turbo may theoreticly be a 900hp turbo, but how much for real, I don't know..? It is quite old school after all. I was going with Pro52 turbo(1300e), but then I found this for 300e so I wanted to try it. Quite easy to change later if not happy. I was thinking of a pressure/vacuum actuator for the valve, it could be operated with exhaust backpressure.
                    OrginalS60, the block is an AEL/D5252T. The clutch is an basic 7.25" twin with Bling factory 3.9kg flywheel. http://www.blingfactory.fi/epages/vi...cts%2FBF200101
                    The release bearing has a custom 01E fitting plate and a bushing to fit the pressure plate right. Did buy the whole kit used, PnP for AAN.
                    • Nice stroker projekt! Are you going to use supercharger also with new setup? Interesting to see how works the exhaust valve. Looks good!
                      • thomas i think the turbo is to big for a I5 20V engine. it is very laggy and a minimal powerband.
                        K27 with #13 housing and with a good compressor wheel is good for more than 800hp....
                        for me a K31 is senseless
                        Audi UrS4 20VT Precision 6262, VEMS, CatCams, SOLD
                        VW T4 TDI Multivan
                        pleasure by pressure...
                        If you are not breaking parts, you're not going fast enough...
                        • What spec would that custom K27 be, must be some $hybrid$ turbo? No way a stock would be good to 800hp. K31 shouldn't be more laggier than a Holset pro55.
                          I'm still going to use the supercharger, and with the quick spool valve a #20 divided housing would be size #10 at the spoolup range. Of course there is a chance that this is a really bad turbo, and may not work good enough on a I5, but can't tell if not trying it.
                          • Thomas, you are a crazy man... but in a good way!!
                            • Originally posted by maiks View Post
                              I agree!
                              Keep going !
                              • Look what arrived today.
                                Can be some small fitting space issues.
