Cool
! There were no dramas for us only issue of the weekend was that there was a roll on the first corner(not us) and the final had to be restarted.
. So season ended and I'm proud to say we won the national rallycross championship in the supercar division. Last few races weren't than succesfull but the results were good enough to secure the gap in the points. During the last race in qualy heat 3 there was a big bang leading to our premature finale. A rod popped out to congratulate the champ I guess. Joking aside the rod punched two holes on both sides of the block and as you can guess that meant new rods and pistons
. The failure was due a cracked rod bolt, the colour difference on the slpit bolt was quite enough to solidify this conclusion. The engine was rebuilt did a new tune without the turbo restritor just for the kicks of it and we got 500whp and 640Nm which we were quite happy with. Should point out the engine has a slightly higher CR than last time about 12:1 with slightly customised JE pistons
. Prep for the new season will begin the following week. Changes that are being disscused are moving the driving position further back and relocation of the radiator to the rear to improve the inherent bad balance of the Audi. The car actually weighs 1200kg and almost 800kg are on the front axle which gives for around 60/40 front rear weight split which is far from ideal. Here is some footage from the last few races:
