1981 UrQuattro story
  • Nace20
    • Jul 2007
    • 721
    • Country: Slovenia
    #46
    we will check evrything around fuel this weekend
    S2 limo
    • chezz
      • Apr 2007
      • 440
      Originally posted by Sküll
      i hope the injectors are not clogged too...
      There is a method of testing the output volume and spray pattern on the CIS system - maybe you will need this information later, if you do not already know the procedure ...You have enough to do for the moment.
      • Skull
        • 3506
        • Country: Slovenia
        #48
        well i have at home set of KP engine injectors that have 2000km behing them, my the VAG code i would say they must be the same as the WR injectors
        KP: 026133551
        WR:049133551A
        opinions?
        Audi Quattro WR
        • pasbogdan
          • Sep 2009
          • 1160
          • Country: Romania
          #49
          KP: 026133551
          WR:049133551A
          opinions?
          What is fuel presure that you see from pump and regulated?
          This is first to measure at a kjetr.
          After that pull all injectors leaving them conected to distribuitor,bridge fuel pump relay and lift(or push,i do not know how 10vt kjet works)the flap that pushes pin inside distribuitor and feeds injectors with fuel.Watch spray patern of injectors.Let the fuel flap into neutral position(no fuel to injectors)and watch for injectors leaking.
          Kow is possible that this car was serviced 3 years by an audi pro and have so much dirt in fuelpump???
          Theese are basic tests for k jetr,after that comes profesional measurements and adjustings that i did not wanted to learn because it does not worth.You should not loose your time with them also.
          What about timing of engine/distribuitor?
          • chezz
            • Apr 2007
            • 440
            KP: 026133551
            WR:049133551A
            opinions?
            The metering of the fuel is not down to the injectors and therefore you may possibly be OK to use these.
            • Skull
              • 3506
              • Country: Slovenia
              #51
              quite some progress yesterday.
              - replaced all engine related vacuum tubes
              - replaced distributor
              - found out that the k-jet plate was sitting way too low, lifted it up almost as it should be
              - found some dodgy wiring on the TSZ, repaired it
              - checked the injectors - ok
              After this we were able to start the engine with no problems, but it wont hold idle.
              next thing is to check the idle switch, idle valve.
              the sparks are still not in order always, so i have to find a pair of the 2 flywheel sensors.
              Audi Quattro WR
              • Skull
                • 3506
                • Country: Slovenia
                #52
                now a fun part...
                there is a pipe that has to find its place:
                somebody connected it to the only free visible space
                Audi Quattro WR
                • DJones
                  • Jun 2005
                  • 2020
                  The tube on the metering head is not a tube it is a pipe/hole for putting a Alan drive down for mixture adjustment.
                  • Skull
                    • 3506
                    • Country: Slovenia
                    #54
                    yeah, i know that, but still wonder where should it go...
                    should the hole for the key be blocked to avoid pressure losses?
                    Audi Quattro WR
                    • pasbogdan
                      • Sep 2009
                      • 1160
                      • Country: Romania
                      #55
                      [QUOTE=Sküll;704781]quite some progress yesterday.
                      [QUOTE]
                      How lover related to the bottom of the cone should plate rest on a turbo kjet?
                      What is the pressure that injectors start to open?
                      What is the regulated fuel pressure on the kjet head?
                      Have you reset the plate position related to the kjet head pin?(with the 3mm key)
                      You work with a turbo aplication kjet manual or with a general one?
                      Good luck!
                      • chezz
                        • Apr 2007
                        • 440
                        Yes
                        • pasbogdan
                          • Sep 2009
                          • 1160
                          • Country: Romania
                          #57
                          Based on what?It is outside vacuum intake line.Manifold-cone-plate.For this forum to mentin its original tech quality i think we all should be 99% sure on what we say
                          • chezz
                            • Apr 2007
                            • 440
                            100% sure....do you understand the question fully? read again I think there is a misunderstanding occuring here
                            • turbofan
                              • May 2008
                              • 30
                              • Country: Latvia
                              #59
                              Maybe this can help you.
                              Webhostingy různých druhů včetně té pro domény druhé úrovně zdarma.
                              Black S2 Avant
                              • 5alive
                                • Feb 2013
                                • 8
                                that should connect to the underside of the plennum,feel underneath and you should find the connection.The correct part to join these two ports looks like a small rubber hose about 10cm long but it actually contains a restrictor/valve so you need to get the part.Even if you fix all the other problems the engine will not run propery without this.
