A lot of work went into this piece right here. First layout, fit and shape. Step roll the edges along the fender. Then run it thru the radius roller some. Brake the two edges, and use the shrinker on the edge along the door to conform the radius. Lastly, bend the bottom brake and the radius which is actually 5 steps; brake a little, pull out 1/8", brake a little, test fit, brake a little on and on.
Still have some to get it perfect and then drill/prep/weld it in. Pull the extension after drilling pilots and put the dzus wires in.
And the other days bow of rain....
this side is done. capped the rocker i built as well. that multi-break piece wasnt easy.
and the mountain tonight looks great.
