Aarons 8's or better RWD tube chassis build
  • speeding-g60
    • Aug 2008
    • 1186
    got the drive mandrel for the mech fuel pump. machined some to fit my pulley. now ordered the belt and just waiting for it to get here.
    And getting the manifold ready for staged injection, two rails, double the amount of injectors.
    Random mountain shot.
    Sent from my SCH-I545 using Tapatalk
    • speeding-g60
      • Aug 2008
      • 1186
      All done with machining.
      Some reraxin.... in the hot tub time machine.
      • andy10v
        • 5996
        Possibly a silly question, but why the mechanical fuel pump?
        Sold ABY-stock
        • speeding-g60
          • Aug 2008
          • 1186
          Going to be using methanol for fuel with no intercooler, dual rails with staged injection and nitrous. The largest electric fuel pump would be on the ragged edge of being overworked. This will be all the fuel I will ever need, flowing almost 5 gallons a minute at 8000 rpm amd 100 psi.
          Remember that methanol will take about twice as much volume as gas will to make the same output.
          Primary injectors will be around 1700-2000cc and the secondaries will be much larger.
          Sent from my SM-G900V using Tapatalk
          • speeding-g60
            • Aug 2008
            • 1186
            Manifold second rail injector bungs are welded in. And belt drive is ready to test in the car now.
            Adjusted the oil dipstick to be functional.
            And can't forget dinner..... filet mignon, bacon wrapped filet, little lobster tails in butter, large shrimp in butter and garlic, and two Rib-eye; 1.5 for me, half for my son. He only eats "Dads kind of steak". And some breaded shrimps from the oven.
            • repo
              • Dec 2004
              • 893
              Another reason, not just capacity, to run a mechanically driven fuel pump is the power consumption of massive electric pumps - especially if there is a number of them. You can't run alternatorless system with three pumps drawing 30-40 amp each AND have proper ignition system.
              And also, if You run tons of electric pumps flat out, and only carry a gallon of fuel to begin with, You'll boil it quicker than You might think. Belt driven pump has variable speed, so on idle it won't fry Your fuel.
              • speeding-g60
                • Aug 2008
                • 1186
                ^^^^^ yep, all of the above. and cost, as well.
                • speeding-g60
                  • Aug 2008
                  • 1186
                  Finally have this thing sitting on the ground. ProMod car needs to be on the chassis jig so off I go.
                  Current one and new one, showing body changes. Specifically wheel arches and location of arches.
                  • ringbearer
                    • Sep 2011
                    • 176
                    Love it! pushing the wheels out makes it look so good
                    • speeding-g60
                      • Aug 2008
                      • 1186
                      dunno where i was with updating, so here is Last weekends work. Mount turbo and door lexan stuff.
                      Fuel pump mounted.
                      Quickie of the Chubhouse I am building for the boy. 8 feet up, enclosed house part is 8 x 12, with 8 x 12 deck which is 4 x 12 Covered and 4 x 12 open. Just a couple random shots of it. Cut a notch in The branches to tuck it up in there.
                      Built the back wall lying flat and stood it up, openable window and all.
                      Sent from my SM-G920V using Tapatalk
                      • speeding-g60
                        • Aug 2008
                        • 1186
                        Been a minute.
                        Turbo manifold looks almost done. logos being water jetted now.
                        • speeding-g60
                          • Aug 2008
                          • 1186
                          And the Chubhouse progresses as well.
                          • ringbearer
                            • Sep 2011
                            • 176
                            Car is looking good but I really like the clubhouse!
                              Go to agree the clubhouse looks brilliant. Lovely work on manifold too
