big day today, got the car painted. few pics of the process.
Euge's LWB Sport Quattro
Collected the car from bodyshop today, picture don’t make her justice....
also got hold of 6 speed subframe and powerflex subframe poly bushes.
Next on the list is KW V3You do not have permission to view this gallery.
This gallery has 5 photos.Comment
Putting it slowly together, sound proofing done, KW's installed and put some temp wheels on to push her around.. Will try to find some time to make some better pictures.
Hi peeps, need a bit of help.
So the car has full s2 suspension set up with Alberts tubular lower wishbones and KW3 coilovers, but the front wheels are a bit offset to the front relatively to the arch centre. any thoughts?
****** pic attached, these are some temp wheels from A5 R18WhatsApp Image 2020-01-03 at 11.08.25.jpegComment
Please don’t slate me if this seems stupid. Is Albert’s tubular wishbone symmetrical? If you look down through this post you’ll see what I mean. I realise these aren’t Albert’s but I can see how it just might be possible to fit it “ upside down” and that might change the centre of the wheel relative to the centre of the arch.
https://www.s2forum.com/forum/member...ular-wishbones 32D4F676-F700-42D5-B8D4-290EC78C9D34.png1996 S2 ABY Coupe silver
2003 S3 8L dolphin grey
2014 RS4 B8 prism silverComment
the wheel is 20-25mm offset in the wheel arch to the front, Albert's wishbones are easily identifiable and all pick up points match the standard s2 whish bones..Please don’t slate me if this seems stupid. Is Albert’s tubular wishbone symmetrical? If you look down through this post you’ll see what I mean. I realise these aren’t Albert’s but I can see how it just might be possible to fit it “ upside down” and that might change the centre of the wheel relative to the centre of the arch.
I'm just curious what are people doing to get the front wheels sitting in the centre of the arch.. offset subframe bushes? offset top mount? or are we doing something completely wrong.Comment
