Projekt Alpinweiss V - Rebuilding the new engine...
  • andy10v
    • 5996
    Good progress, but needs more pictures
    Sold ABY-stock
      more pics! Where is this new engine you speak of?
      • Rusty
        • 18953
        New block went in 2 weeks ago and now has the head, water pump, cambelt & pulley, exhaust & a few other things on it. Taking my time, cleaning & refurbishing and replacing bolts with stainless as I go. Starting to look like an engine and is all timed up and torqued down now.
        The vacuum conversion on the brakes was a pig with the ABY fuel lines but I've sorted that with brute force and so just have to get a vacuum connection to the servo and adjust the rod in the car.
        Pictures are on my camera so will update when I'm on an actual computer.
        Fingers crossed for being close come Sunday...
        • Rusty
          • 18953
          Some pictures.
          • New ABY block built by Aelred Smith
          • FCP Engineering X beam rods and 81.5mm pistons
          • RS2 water pump and billet crank pully by James Dorey
          • Lightened 7A flywheel with an SRE organic clutch & INA metal release bearing
          • Baffled sump
          • JNL Racing head with ported exhaust and multi angle valve seats
          • JNL Racing port matched OE inlet manifold
          • RS2 cambelt, INA tensioner & new chain
          • NGK BKR7EIX plugs gapped to 0.6mm
          • Vacuum brake servo conversion
          • Lots of painting and cleaning!
          • Stainless fasteners, where appropriate
          • Engine timing
          • Lots, lots more...
          • K Simmonds
            • Dec 2007
            • 7627
            Looking great Andy, you must be dying to get running!
            What's the 3rd photo of mate? I can't quite work it out looks like a hinge,
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • AndyP
              • 6049
              Oil control flap for the sump??
              • SteveH
                • 4460
                Good progress Andy
                91 Modded 3B
                14 A6 Avant Black Edition
                • Thuppu
                  • 4115
                  Wow, nice, shiny, bits, nice, wow!
                  • Rusty
                    • 18953
                    Spotter's badge.
                    • rxl
                      • 1913
                      good progress
                      • diesel des
                        • 3896
                        #71
                        Originally posted by Rusty
                        Spotter's badge.
                        Would be good if you could post some more sump details. I would like to do something like that in my urq.
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Ahh, I should have got that, well spotted indeed.
                          I'd also be interested to see a pic of the inside of the sump so I can get a better idea of what's been done altogether.
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • Rusty
                            • 18953
                            The sump was modified for me by Aelred Smith, so not sure where he took it. I'll drop him line.
                            Got the inlet, PAS pump and a few other bits on as well as more cleaning and painting & figuring out the vacuum servo connection before coming down with the lurgy yesterday. Not felt this rough for a while...
                            • gnutz2
                              • Aug 2006
                              • 928
                              That view is from the side of the sump with the wing removed. Its a good mod and made a big difference on my car.
                              The ONLY S2 Golf!
                              10.42@138mph
                              • diesel des
                                • 3896
                                #75
                                Yep is it something that aelred still does. Cost would be nice.
