Titanium Grey S4 Avant
I forget sometimes what a beautiful country we live in, ace pics cars looking fine glad you feel the love again
Terrific shots, Janis!!
Can we see some more shots under the bonnet too?!
Did you take the valve cover and inlet manifold off and have them
blasted and painted?1997 Audi S6 - The Purple Helmet!Comment
She's getting there.
Thanks Craig.
Tbh under bonnet is a mess currently because of all the problem chasing I did it. I made a big mistake and used lacquer on engine bay parts so it quickly got dirty and it ain't coming out. So when LPG is going on I might repaint rocker cover and manifold
want to modify coil cover too so I can fit that too.
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
They have a big safety factor. Typical propane pressure at normal UK temperatures is somewhat less than 10 bar. There is a relief valve set at about 18 bar and a lead plug that melts in a fire to safely vent the contents in a controlled way insead of relying on the relief valve alone. All the valves and safety devices are housed in a sealed box that is vented outside the cabbin. Also all the wires and pipes go through a conduit from this sealed box to outside the cabin.
By the time the lead plug melts at 150 deg c plus the car is toast anyhow so safely venting Lpg below the car is much safer than the catastrophic failure of the pressure vessel.
Sent from my LG-H955 using TapatalkComment
Right Click remote wiring
That looks like the same one as I have and installed. Did you every give me the Part Number on the central locking and light control module under the rear seat? I can help you with the wiring.
I was going to document what I did for my 94 V8 S4 avant which came with only central keyed locking (no remote whatsoever) but it looks like I should do the documentation so others can see it too.
You have to have at least central keyed locking to play this radio frequency remote and alarm game.
Yes that would be great DaveI was going to document what I did for my 94 V8 S4 avant which came with only central keyed locking (no remote whatsoever) but it looks like I should do the documentation so others can see it too.
, I'm guessing mine is the same? , not sure really ,I can lock / unlock all doors by turning key twice on driver side .
(Sorry for going off on a tangent hunker7)sigpic
Cab 2.3E
90q
URS6Comment
