Project 91 Coupe to AAN'd 400+HP SSSSSSSSSSomething
  • elijahallens2
    • Aug 2004
    • 310
    #91
    Hey all, its been a while since I posted on my ongoing project. I have had the car to the track once again this month and once again had some more issues. The RS tuning tube header I am using developed a crack due to the WG pipe not being mounted. The crack is just around the base of the pipe that holds the WG so I should be able to get it welded and brace it off well enough for the next event or untill I get the new header built. The other problem I was having was boost kept being held back after four or five laps. It would go from 24ish down to max of 10-12psi. Still not sure whats causing this but it seems heat related. Other than that the car ran great. I have it at a friends shop now and this weekend plan to do the DSY 6 speed swap as well as the 044 Bosch Motorsport fuel pump. I also just got a 928 S4 MAF that I am sending off to be reprogramed to work with my setup and hope to have that in soon as well. Here is a picture of the 928 MAF next to the RS2 unit.
    Elijah
    91 Audi Coupe Quattro- AAN engine transplant
    • elijahallens2
      • Aug 2004
      • 310
      #92
      here is a picture of the two MAF's with the 044 Fuel pump between them..
      • elijahallens2
        • Aug 2004
        • 310
        #93
        Here is a picture of the RS2 shift linkage for the tranny swap. I also have a B4 front subframe, 4000Q propshaft, and S2 ABY front halfshafts to make this work.
        • A1QSHIP
          • Aug 2004
          • 975
          Elijah, what are the p/ns cast into the aluminum mounts for the transmission?
          Thanks, Chris
          "Nulla tenaci invia est via"
          • elijahallens2
            • Aug 2004
            • 310
            #95
            I'll look when I'm at the shop tomorrow. They are the RS2 trans brackets.
            Elijah
            • elijahallens2
              • Aug 2004
              • 310
              #96
              Thanks, Chris
              Chris,
              Right side is 8A0 399 114 E
              Left Side 8A0 399 113 E
              Elijah
              • elijahallens2
                • Aug 2004
                • 310
                #97
                Hey guys, ok little recap of progress, car is running well other than MAF's
                being eaten every week or so (think I have this problem figured out), I am
                putting the DSY 6 speed in this weekend and first problem is I can't get it to
                go in reverse, I have the RS2 shift linkage and shifter but as soon as it feels
                like its going in it just stops. Second problem is the clutch pedal feels like
                it only goes part way down before it just stops. This is the same clutch and
                pressure plate that I used with the stock coupe tranny, could this be the
                problem?? Also, is the coupe TOB the same as the AAN TOB (throw out bearing)?
                Elijah
                • elijahallens2
                  • Aug 2004
                  • 310
                  #98
                  6 speed in place.
                  • elijahallens2
                    • Aug 2004
                    • 310
                    #99
                    Exhaust hits new tranny, more work
                    • elijahallens2
                      • Aug 2004
                      • 310
                      #100
                      Procon 10 bracket needed to be cut, done.
                      • elijahallens2
                        • Aug 2004
                        • 310
                        #101
                        Speed sensor needs to be pulled out of the way of the RS2 shifter and closer look at cut on the procon 10 bracket.
                        • elijahallens2
                          • Aug 2004
                          • 310
                          #102
                          Old subframe next to new B4 subframe
                          • elijahallens2
                            • Aug 2004
                            • 310
                            #103
                            Coupe propshaft next to 4000 rear DS.
                            • elijahallens2
                              • Aug 2004
                              • 310
                              #104
                              Coupe front halfshafts next to S2 front halfshafts.
                              • elijahallens2
                                • Aug 2004
                                • 310
                                #105
                                Poor car waiting for answers..
