Project 91 Coupe to AAN'd 400+HP SSSSSSSSSSomething
  • Chris M
    • Sep 2003
    • 1030
    Originally posted by elijahallens2
    The other problem I was having was boost kept being held back after four or five laps. It would go from 24ish down to max of 10-12psi. Still not sure whats causing this but it seems heat related. Elijah
    I had the same problem with my S2, after 3 or 4 laps i'd lose about half my boost I checked all the hoses (Samco's fitted) and nothing. Give it ten - fifteen minuites and i'd have full boost again Turns out it was a faulty Bailey Diverter valve. 710N fitted, problem solved (for 5 months)
    Good luck with the car, its looking great. Nice one
    Cheers,
    Chris
    Cheers,
    Chris
    Silver S2 Avant : Sold
    • elijahallens2
      • Aug 2004
      • 310
      #107
      Thanks Chris, I also have a Bailey valve and thats one place I still haven't checked. Its going on 3 years old to so hopefully thats the problem. Now if I can just figure out why my clutch pedal stops just before it goes to the floor (wrong clutch??maybe) .
      Elijah
      91 Audi Coupe Quattro- AAN engine transplant
      • Chris M
        • Sep 2003
        • 1030
        Hopefully that'll be the source of the problem. Good luck
        Cheers,
        Chris
        Cheers,
        Chris
        • Audilard
          • Oct 2003
          • 87
          Alright, now that I've found this thread and seen ALL the pictures, I'm totally hooked on the ssr complites!!!!!!!!!!!!
          Darin
          1989 Audi 80tq
          • elijahallens2
            • Aug 2004
            • 310
            #110
            Finally got a chance to work on the car again and I feel really stupid. The reason I couldn't get it to shift into reverse is that there was an unused bung that I couldn't see that was hitting the shift linkage just before it went in. I trimmed it back and now it shifts perfect through all gears. The first time when I measured the halfshafts I just stood them on end and forgot to see where the cv joint was in proportion to the shaft, we''ll sure enough one was up a little making them appear to be the same length. Switched them around and they fit perfect . Bolted the 4000 rear driveshaft in and it all seems to be great. Just got my new delrin front control arm bushings so once those are in its time for a test drive.
            Elijah
            • elijahallens2
              • Aug 2004
              • 310
              #111
              Went for a drive with the new 6 speed installed, it shifts smooth and I am very happy with the overall feel. I am still struggling with an unstable idle problem though. Once the car warms up the idle starts to surge up to 2K then down and almost stalls, it does this over and over and the hotter it is the worse it is. Any idea's? My guess is another MAF or maybe the lamda sensor. I hope to get this figured out before I rework the intake with the new 928 S4 MAF. I have also decided to have a new header built to give me more room for 4" intake tubing.
              Elijah
              • martinjs
                • 3205
                Give your ISV a clean elijah, may cure the idle problem.
                • ~Delta
                  • Apr 2005
                  • 797
                  #113
                  Sounds like it's running rich, if it's hunting once warmed up.
                  Never show a fool a half built house.
                  Never underestimate the power of stupid people in large groups.
                  Life is like a **** sandwich
                  The more bread you have, the less **** you eat
                  • elijahallens2
                    • Aug 2004
                    • 310
                    #114
                    Yes, its running very rich.
                    • elijahallens2
                      • Aug 2004
                      • 310
                      #115
                      Found the unstable idle problem was just another MAF with broken hot wire. Thats number 4. The car is running strong again and is now in for a new header and intake setup. I also got my S8 caliper carriers and VW modified rotors for the rear. Here is a picture of them next to the stock rear on my winter beater coupe. This is using the urs4/6 caliper and S8 carrier. The rotors are 280X25 vented .
                      Elijah
                      • kwlw
                        • Sep 2004
                        • 1025
                        • Country: Lithuania
                        #116
                        Elijah
                        Do you have any tips on converting A8 disc with ten 5x112 holes to 4x108 ?
                        Sau
                        • ~Delta
                          • Apr 2005
                          • 797
                          #117
                          I wouldn't convert a 10 hole disc to run 4! There'll be little metal left to mount them securely, imagine one of those shattering hauling the car down from high speeds, doesen't bear thinking about.
                          Why not convert your car to S2 hubs? A lot safer, and easier to do as well.
                          • kwlw
                            • Sep 2004
                            • 1025
                            #118
                            First economical reasons. If I had enough money I was driving A2 quattro and Evo6 combo (depending on mood) . S2 hubs cost me half of the S2. I don't like spending lots of money for "almost nothing". I'd rather spend them for the solution which will be one I like .
                            Next - holes of the brake disc are not taking so much abuse as you think. Brake discs are pressed to the hub by the wheel. There's plenty of friction between them. However if wheel is not bolted properly - there's possibility to loose one wheel braking.
                            Third - I've always used to make (or at least to design ) complicated and ineffective (read - stupid ) things. One of my ideas to increase safety and reliability of drilled from 10x112 to ?x108 disc is to use additional security bolt to the weel hub. Next (sophisticated one) is multilayer wheel spacer - converter from 4x108 to 5x112 . The most simple solution (not mine - because it's too good) - to weld "unnecessary" holes (fill them with metal) on the disk.
                            So I do not want to migrate to s2 hubs and will try to find the solution how to bolt bigger discs on 4x108. However practice showed, that normal ppl can solve many problems I am struggling in very elegant, cheap and practical way . That's why am asking in this thread .
                            Anyway thank's for warning
                            Sau
                            • elijahallens2
                              • Aug 2004
                              • 310
                              #119
                              Sau
                              Sau,
                              Sorry, wish I had some good advise but I just don't know. As long as you have enough metal I don't see a problem with just re drilling the 4x108 pattern. Good luck with it .
                              Elijah
                              • MidnightBlueS2
                                • Jul 2005
                                • 1653
                                • Home: United States Current: Belgium
                                #120
                                Hi Elijah,
                                Saw you were online... How's your project coming along ?
                                Midnight Blue S2 - SOLD - 1993 S2 Avant
