Replaced the throttle body hose and WOW! Feels like whole different car now. Also repaired the broken sunroof. It was fairly easy since everyhting it needed was a new motor. Just bolted it on and now I can enjoy the short Finnish summer
Speaking about summer and the few hot days we had, I realized that my AC was not working. Took a quick look under the bonnet and my compressor was not turning. Pulled the codes from the climate control panel and it seems that the low pressure switch prevents the compressor from starting. Then I opened one coupling after the condenser just to see the system is completely empty. Some of the hoses were badly cracked so I'm going to have to buy new ones. Genuine items from Audi Tradition are between 100 and 250 euros
Hopefully some AC shops in here can make me new refrigerant hoses based on the old ones.
Also intermittent wipers are not working. Bought the new relay for that but it seems that was not the cause. I'm assuming there is something wrong in the stalk itself.
Interior lights are faulty too. They work normally when I turn them on but nothing happens when the switch is set to turn them on when door is open. Quick look to wiring diagrams showed that the interior lights are controlled via the V94. I guess I have to dig out my multimeter and start measuring
So it's one problem solved and many more to be solved!
Hopefully some AC shops in here can make me new refrigerant hoses based on the old ones.Also intermittent wipers are not working. Bought the new relay for that but it seems that was not the cause. I'm assuming there is something wrong in the stalk itself.
My guess is that I never should have repaired the threads of the end cap. Live & learn
