S2 Avant -93
  • Antsa
    • Nov 2016
    • 611
    ​Deleted due to missing photos
    • rxl
      • 1913
      Cant see the pictures
      Gesendet von meinem CPH2371 mit Tapatalk
      • Antsa
        • Nov 2016
        • 611
        It seems that way that I can see the photos on my device but I tried on wifes phone and couldn't see them either. I'll have to repost tomorrow
        • Antsa
          • Nov 2016
          • 611
          We've been having quite cold weathers here so there was no working outside on the car. To pass the time bought a used starter to disassemble and rebuild. This is not too sensible (money wise) since a new Bosch unit is still available for around 150 euros but its no fun buying new parts, is it?
          Here's the starter that I bought
          Took it apart. The dust from the carbon brushes inside the cover is messy and gets everywhere. I was little surprised to find out that there are no rolling bearings inside a starter but just bronze bushings instead.
          These small rubber pieces hold the outer planetary gear to the plastic housing. These were past their best and had cracks.
          As they are not supplied with a rebuild kit and I could not find them anywhere else, I drew them in cad and send out to a friend to 3D print them. To a little surprise the first batch was a good fit straight away.
          Every piece got cleaned and the aluminum front part was glass bead blasted and treated with acf50. Now waiting for AutoDoc to up their game and ship me the parts that I ordered two weeks ago, then I can start the rebuild
          • Antsa
            • Nov 2016
            • 611
            I reposted everything. Are the pics now ok?
              • Dec 2017
              • 5984
              I can see them now. Nice work
              • Antsa
                • Nov 2016
                • 611
                Thanks Dave! I've been enjoying your Ur thread, what a fast progress!
                • Antsa
                  • Nov 2016
                  • 611
                  I also managed to break the luggage boot handle during the cold weathers. The boot door was frozen, I pulled too hard on the handle and managed to break it. I made a little fixture from threaded rod plus nuts and washers to keep the broken piece aligned when welding. However it turns out that the handle is made from somekind of unweldable aluminum. Suspecting this would happen I had already ordered a used handle but they are pretty expensive with 100e price tag
                  Both my original and the replacement handle rubber gaskets have little tears like this one. I went to local industrial store to look for some rubber superglue but they were out of stock and and had to ordered.
                  Autodoc has finally shipped my order so once it arrives I can start putting the starter back together
                  • Antsa
                    • Nov 2016
                    • 611
                    So my attempt to glue the tears on the boot handle gasket did not work, the glue just won't stick. They went back as is.
                    But autodoc finally delivered
                    New carbon brushes plus solenoid
                    However I'm not too happy with the solenoid. It says made in china, it is missing the plunger, no markings of the terminals on the backside and it did not come in a Bosch sealed box (could this be a counterfeit item?). So I'm going to make this one a spare and reuse the old solenoid.
                    • Antsa
                      • Nov 2016
                      • 611
                      Now that I have all the parts that I need, I could start the rebeuild. This is a kit from tradition.
                      Gears got greased
                      There is a stopping sleeve on the shaft that prevents the starter gear going too far. The sleeve is kept in place with a lock ring which lives inside the sleeve. It was a little tricky to get in place
                      I used a puller to gently lift the sleeve in place. As the sleeve slides upward it compresses the lock ring and finally snaps in place
                      The lock ring inside the sleeve
                      Brushes in place
                      Whole starter assembled. The black casing propably needs painting but I don't have access to a spray booth so it will have to wait for summer. Also the heat shield for the solenoid could benefit from cleaning but fortunately it's easy to take out if it bothers me. I also quickly tested the starter and it worked fine.
                      • Antsa
                        • Nov 2016
                        • 611
                        After seven years of S2 ownership I finally rented myself a garage to get the project really started.
                        The interior is almost taken out, the headlining still needs to be removed.
                        Before starting on the headlining I'm going to have to carefully remove all of this wiring loom mess
                        • rxl
                          • 1913
                          Wow looks like something big is going to happen. What are the Plans?
                          • Antsa
                            • Nov 2016
                            • 611
                            My plan is currently the following
                            Remove whole interior, engine, gearbox and subframes
                            Replace rear quarter panels and left and right bottom of the trunk
                            Strip whole bottom of the car to bare metal, repair possible corrosion damages and spray new underseal
                            New paint
                            Soundproofing the interior
                            Strip engine and rebuild to make ~450hp
                            Strip gearbox, replace 1-2 shift collar and synchro and all seals
                            Put everything back together
                            Honestly I'm a little terrified since it is going to be a major task, but I've tried my best to get all the information possible to successfully get everything done.
                            I'll try and make updates regularly
                            • Nuvo
                              • Nov 2003
                              • 3825
                              #224
                              Wowzers! That's no small undertaking. I'm sure I speak for others when I say that I look forward to reading about your progress in this mamoth endeavour.
                              Bon chance mon ami!
                              • rxl
                                • 1913
                                Time for some Popcorn.. Wil be a long way but worth it
