VEMS I5 Maps
This is a sticky topic.
  • Car is hard to start at low temperatures below 5 degree celsius.[/QUOTE]
    E85 does not like the cold, that's why the run E75 in winter
    RS 2 580HP
    • Shouldn't be any problems at those temps if enough enrichment. -20C is a different thing.
      • Hi, here's a config with working settings for E75 cold start enrichment (on my car anyway), tested down to about -5 degrees Celcius. Use settings at your own risk!!
        Leif-Helge
        -91 S2 VEMS and Comp Turbo
        -12 B** 530XD Touring "S2 parts transporter, and daily driver"
        • Originally posted by jade View Post
          I started an I5 in -10C on E85 that I mixed myself last week. Started after 3-4 cranks just fine.
          E75 you need for -15C and below.
          Get your maps right, and your car will start fine. At 5c only poor mapping is to blame, not the fuel.
          • Dmitri, my car started in -15 after few attempts. Your coldstart setups made in summertime and in like 5min.
            • My car is doing lots of misfires on warmup with these cold temps. When the coolant temps are OK it is fine. It is on ultimate pump gas now. Should I change something?
              '95 RS2
              • Thank you dkw_dude. Now it starts nicely.
                • Nice. Glad I could help..
                  Leif-Helge
                  • Originally posted by snaak View Post
                    Turned out my spark plugs (iridium) and ls2 coils were causing the problems. LS2 coils did not more than 5000KM bought at efiexpress. What shoukd I do, buy new LS2 or go tfsi coils?
                    '95 RS2
                    • AAN, E85, HX 40 Super 16#, ID1000, 4bar (58psi) FP, Walbro 450 lph E85, machined Head
                      408kw @ wheel
                      • Have you been on a dyno with that setup?
                        Go Holset or Go RS4
                        • hi Billman I was unfortunately on no dyno . I just measured with a pbox.
                          408kw @ wheel
                          • Would anyone with a well tuned set up be willing to post a screen shot of there timing map and a quick summary of their set up. I don't have vems so can't open the map files on this thread but I'm curious how my timing map compares.
                            • setup see above...
                              408kw @ wheel
                              • You can download vemstune for free and open all the files!
                                Go Holset or Go RS4
