VEMS I5 Maps
This is a sticky topic.
  • KRIENG
    • Apr 2009
    • 68
    • Country: Thailand
    #196
    VE is easy try to set = EGO corr Ve
    when no acc enrich , no de acc
    • danycheung
      • Nov 2012
      • 11
      • Country: Costa Rica
      #197
      hey KRIENG,
      what fuel are you running?
      what turbo?
      engine specs?
      just commenting.. i see mat a little hot with 25deg of spark..
      • KRIENG
        • Apr 2009
        • 68
        • Country: Thailand
        #198
        Originally posted by danycheung
        hey KRIENG,
        what turbo?
        engine specs?
        AAN Rs2Turbo E85 Flexfuel Sensor
        I will try ignition for best power by use Virtual Dyno
        • danycheung
          • Nov 2012
          • 11
          #199
          • vwnut8392
            • Jul 2012
            • 418
            Might anyone here have a base map for a bone stock AAN using the PNP ECU? im looking for something to start my car on and refine from there.
            my list of mods are....
            -7A cams
            -ebay tubular manifold
            -T3 T04E 50trim .63 A/R exhaust
            -3in downpipe and catless exhaust
            -front mount intercooler
            -external dump wastegate
            -RS2 injectors
            -stock AAN FPR at the moment
            If someone has something close to my setup that would be cool too.
            thanks guys.
            "The really good drivers got the bugs on the side windows." Walter Röhrl
            • ChErRyMoOn_S2
              • Mar 2011
              • 34
              • Country: France
              #201
              hello,
              I want a 55 VEMS file for starting my Audi S2 3B with such configuration
              -GT3071R
              -630cc siemens
              Ignition coils -5 TFSI
              I would put the progress of my work on VEMS forum
              thank you cordially
              • yannS2
                • Mar 2008
                • 75
                • Country: France
                #202
                very nice
                Audi S2 GT3076 - Full Wagner - Brake RS2
                • ChErRyMoOn_S2
                  • Mar 2011
                  • 34
                  • Country: France
                  #203
                  hello, the car starts on 2 cylinder, the ignition wiring is correct, I am coil tfsi .Who can give me some help?
                    #204
                    What is your coil dwell time set for ?
                    Should be 2.0 - 2.5ms at 12V... more at lower volts but I don't have the factory data on those coils
                    • ChErRyMoOn_S2
                      • Mar 2011
                      • 34
                      • Country: France
                      #205
                      the coils are:
                      TFSI 06E905115E Audi R8
                      thank you for your help
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #206
                        can you post the wirediagram that you have used for your custom coil wireloom?
                        TWINCHARGED power,zero lag
                        AEM W/M injection
                        • ChErRyMoOn_S2
                          • Mar 2011
                          • 34
                          • Country: France
                          #207
                          I got the order ignition provided by VEMS was not correct !!
                          Cylinder: 1 EC36 Pin 35
                          2 EC36 Pin 33
                          4 EC36 Pin 10
                          5 EC36 Pin 12
                          3 EC36 PIN 11
                          injectors:
                          Cylinder 1 20
                          """" 2 8
                          """" 4 9
                          """" 5 19
                          """" 3 7
                          Now, I'll start setting up map
                          • GazzaG60
                            • 4133
                            that depends on whether its aan or ABY.
                            aan wired different and vems knowledge is usually for aan
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              #209
                              i use vems with a AAN engine so if you need some info just give me a sign
                              AEM W/M injection
                              • dich
                                • Apr 2010
                                • 52
                                • Country: Bulgaria
                                #210
                                This is my map for:
                                stock head
                                stock bottom end excluding rods
                                e85
                                2.3 bar
                                1680 cc injectors
                                holset hx 52 pro
                                tfsi coils
                                Car is hard to start at low temperatures below 5 degree celsius.
