Originally posted by Prosac
View Post
VEMS I5 Maps
This is a sticky topic.
Originally posted by Frittjoff20 View PostDamn you guys run low ignition timing.
cant upload my config at the moment but the ignition timing looks similar to Prosacs.
Aan
Gt35
Aan camshafts
Aan head
Other rods orginal pistons
siement 630cc
shell v-power
That won't last forever I believe.
Anything above 14deg at spool of my turbo will ping with 98 octane here in the UK so I don't risk it.
Originally posted by A80Avant View PostSo you run E85 ignition timing on she v-power?
My compression ratio is higher than what others use and recommend. It's around 9:1 but even on lower ratios I have heard and seen maps not going much higher than 15-16 deg. Of course that rises with RPM but the most pinging I have experienced was at the onset of the high boost, around the spool area. I'm also talking about the above timing with stock rs2 cams.
Strokers are a different story.
Originally posted by A80Avant View PostMy compression ratio is higher than what others use and recommend. It's around 9:1 but even on lower ratios I have heard and seen maps not going much higher than 15-16 deg. Of course that rises with RPM but the most pinging I have experienced was at the onset of the high boost, around the spool area. I'm also talking about the above timing with stock rs2 cams.
Hello! I need a map for Vems v3. S2 ABY , JE Pistons, ferrea valves,
crankshaft knife. SCAT rods, TFSI Coils, ron 98, Gtx3582r, rs2 cams, aan intake,3'' exhaust, siemens deka 840cc@3bar,BOV 50mm, walbro 450l/h , Someone has something similar, or can recommend me to whom to go?? thanks!!!!
Originally posted by Billman View PostSince many people are interested in VEMS maps i thought that maybe it is time to share some maps with you.
*********WARNING*******HANDLE WITH CARE*************
im looking for some guidense in this... i have an stock engine with vems and i want to squeeze every single hp of the stock set up (yes...everything is stock exept a manual boost controller)
Thank you in advance!
- 1 like
Originally posted by S2ABYGTX View PostHello! I need a map for Vems v3. S2 ABY , JE Pistons, ferrea valves,
pls write PM, I could give u base map for your setup. But just for startup and cruisedrive. For power u need a individual mapping.
RegardsAudi Coupe Typ89 10V Turbo - VEMS - Billet K26 - Deka 630 - E85 - 3" Exhaust
Hoping to get a basemap for my new VEMS PnP setup that I will be installing in the near future.
Second-Hand VEMS PnP with "RS2" basemap loaded (I think)
AAN with stock internals
Volvo K24-7400 with Porsche 951 hotside
60lb injectors
044 fuel pump (relayed)
RS2 Exhaust Manifold
Stromung Downpipe (Gen 3) and Exhaust system (Gen 5)
Norbitron TFSI Coil Conversion
Thanks
