VEMS I5 Maps
This is a sticky topic.
  • blackS2
    • Apr 2010
    • 455
    We are on 1.1.96 yet... the cars running fine... but sometimes the 6500 rpm sh** on the Audi Trigger car
    my friends are using the 60-2 VW Trigger... but I'm to lazy to take the gearbox out
    [__]=oooo=[__]
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #152
      Mine does that as well but has no implication to the engine. Its just a small glitch of vems. Fueling and engine works fine so its just psychological. I'm not worried
      sent with Nokia 6210
      • prj
        • Mar 2010
        • 6308
        To be fully correct - the implication is reduced ignition angle precision.
        Of course on a practical level it can be OK, but it is not fully correct to say that "it does nothing at all".
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          #154
          Vems records a trigger error in the log but it causes no ignition timing changes- delays- obstructions- misfires- or any other word you can think of. The precision you are referring to is not causing any performance issues either.
          At that rpm and timing/fueling of there was a true problem there my engine would have been in shreds by now
          I cannot be more clear than that.
          • prj
            • Mar 2010
            • 6308
            It can not run without trigger. A trigger error as I understand is an edge that is not recognized. It can be interpolated, but there is momentary loss of precision.
            Of course this is probably handled safely and timing is late rather than early.
            So I disagree with you in theory, but I agree that if it is one or two teeth skipped, then there is probably not a really measurable difference there from the standpoint of the practical working engine.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #156
              Whatever....
              • Biturbo
                • Aug 2011
                • 591
                • Home: Lithuania Current: United Kingdom
                #157
                I had same on original setup and that was no problem car was running fine.With 7a flywheel, that was really bed till I'm not put sensor closer ant download 1.2.2 firmware now no any errors at all.That can try people who have this problem
                • blackS2
                  • Apr 2010
                  • 455
                  I agree... and the trigger error makes me sick it feels like a missfire for a millisecond
                  [__]=oooo=[__]
                  • marcusaudi20v
                    • Nov 2007
                    • 43
                    Hast du am G4 sensor die Kabel getauscht?
                    Bei einem Freund hatte ich das gleiche Problem mit der 1.2.4 Firmware
                    mit der 1.1.96 ist es nun weg
                    Was noch Probleme macht wenn der Pin zum Induktivsensor zu weit entfernt ist.Also größer > 0,5mm oder der Stift zu kurz ist
                    Gruß
                    • blackS2
                      • Apr 2010
                      • 455
                      Gruß
                      this is all well known an done... but still having a single missfire sometimes...
                      ...maybe I have to check the gaps again
                      (hey man schreibt nicht in ner Fremdsprache des Gastgebers ;-) )
                      [__]=oooo=[__]
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #161
                        My sensor has been so close that during a manual rotation of the crank it touched ad broke it. So I know its not the sensor. In my case it may be the fact that I had to weld a larger pin and it may be slightly larger than it should. But it works and I haven't given it a second thought.
                        By the way, I don't understand the logic of divide by 27 when the developers say use 9. how do you end up choosing which one? At random?
                        • murat
                          • Oct 2005
                          • 167
                          • Country: Turkey
                          #162
                          When I go from divby3 to divby9 I think my trigger errors increased in high rpms. Whta could be the reason, any ideas??
                          Murat
                          • Biturbo
                            • Aug 2011
                            • 591
                            #163
                            Was same for my car,than I go divby27 and was much better.
                            • murat
                              • Oct 2005
                              • 167
                              • Country: Turkey
                              #164
                              Let me try also divby27
                              Murat
                              • Biturbo
                                • Aug 2011
                                • 591
                                #165
                                Did you try this?
