996 Brake conversion
This is a sticky topic.
    I have tried to pull together a few threads as a reference for those doing the 996 brake conversions.
    There is a good link from a forum member with details too
    Here are some links to various fitting threads
    If anyone has more info to add please post into here
  • s2driveruk
    • 12696
    good call Greg - should these be put into Guides and top tips under a braking header?
    1992 3b S2 Coupe
      there is a redirect in the guides and top tips section
      • Paulgo
        • Jan 2005
        • 498
        cheers! Extremely timely for me this as Im just in the process of purchasing the rotors/pads/brackets/lines et al needed to get my recently acquired Boxster S calipers on the car where they belong!
        Only thing left to source is the spring plate/pin assembly thinghy on the top of the pads - prolly be the stealers unless anyone has a spare ! as Ive only the one!
        cheers
        Paul
        • Alistair C
          • 693
          The original 996 fitting thread - 7 pages of discussion & photos, but very informative.
          • 400hp_project
            • Mar 2006
            • 77
            • Country: Spain
            Excellent post!!!!
            I have a quaetsion about brake lines, i bought ones to vagparts that arrived me yesterday, i see the lines that arrived me and i think that it's wrong, my brake lines seems to short and conections to calipers seems wrong, could someone help me?
            Thanks
            • Paulgo
              • Jan 2005
              • 498
              Hi
              looks like the same problem I had - the Brembo kit I got from Vagparts had 2 female ends - whereas the 996 needs a 10mm male fitting at the caliper end. I know they are working on a solution (and happily refunded me ) so I got mine made up locally by a great bloke now a member of the forum called Autopipe (Jimmy), which is also the name of the company in Gateshead. Linky here
              Really good quality braided stainless lines, plastic sheathed with crimped fittings and the choice of a banjo if you prefer (you might need 4x 10mm copper washers if you do). You also need a female convex 10mm fitting on the other end. I went for a length of about a foot and half which was a little too long tho ok, but I guess it depends on where you want to run the line to. We just removed the short pipe from the Girling caliper to the short section of hard pipe around the strut so the vag parts pipes of about a foot in length would've been fine in that respect.
              HTH
              cheers
              Paul
              • 400hp_project
                • Mar 2006
                • 77
                • Country: Spain
                Yes Paulgo it's the problem i have with the brake lines.
                I speak with Autopipe by pm
                Thanks
                • meep
                  • May 2005
                  • 203
                  I have a question. What bolt did u guys use to fasten the caliper in the bracket? Is there a replacement bolt? If i need to buy a bolt from a suplier what dimensions should i get and inclination of the thread?
                  • andy e
                    • Sep 2005
                    • 70
                    I bought the bolts that go from caliper to bracket from a Porsche dealership.
                    I'd like to know how much needs maching off the seat calipers (retaining 16" avus wheels) and where it needs to be taken off.
                    Cheers Andy e
                    • meep
                      • May 2005
                      • 203
                      Ahhh i need to ask them then. Thank you.
                      • AUDI9020V
                        • Sep 2005
                        • 653
                        can you also get the part numbeers for the 4 stud discs too,this is for the 90 as iam trying to work out the cost of it all,or would it be easyer to do a 5 stud convertion on it at the same time.john
                        1990 100 2.2 10vqt 82k miles(now dead)
                        1990 90 2.3 20v 166k miles
                        1988 90 2.0 10v 181k miles
                        oh and a polo for work.
                        • meep
                          • May 2005
                          • 203
                          If anyone would happen to wounder what the porsche part number for the bolts between Caliper and bracket is then here it is 999 067 041 09
                          • BrianSmith_S2
                            • Jun 2005
                            • 1342
                            • Home: Northern Ireland Current: British Antarctic Territory
                            have a set of 4 stud cross drilled black diamond front discs for sale if your interested. came off my 20V coupe. only done a few miles.
                            pm me if your interested.
                            Brian
                            • meep
                              • May 2005
                              • 203
                              Brian
                              Ohhh have you tried thoose? im interested in thoose due to the the cost of them. Are they worth a try or? Checked out DBA discs but they where rather expensive. Blackdiamond seems pretty ok priced. Question is can they take the abuse?
