K24R 300mm / 314mm budget rear brake upgrade
Right, thanks to Kev for the brackets and to RE2500 (James) for the car and help
I'll let the pictures do the talking.Attached Files- P1030603.JPG (992.7 KB, 193 views)
A couple more:Cheers'en, AndyC
Looking good...whats the toal cost of this as an bolt on upgrade inc discs? Looking at my rears today, they are looking tired and timing looks good for a change rather than bolting on another set of 5p piece sized rears
1992 3b S2 CoupeComment
Yup, 5x114 72mm bore. Take the holes out to 17mm, fit the spigot, bolt on the bracket. Done. We had to do some fettling, as I'd been very cautious with the bracket design and made it a tad tight... I.e. negative clearance
James and I made the appropriate changes to the design, so I'll get a quote.
Do people want 302s or 314s? Be good to get an idea if numbers...Cheers'en, AndyC
my tommi makinen rotors are 5x114.3 too .... do you mean that "maybe" could be used in our front hubs too with easy mods drilling?
good work Andy,as always
by the way... what is it a spigot? do you have a picture?RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
LWB Audi Sport Quattro projectComment
I think 314 would be great, if they fit in the 16" AVUS. Otherwise 302.Yup, 5x114 72mm bore. Take the holes out to 17mm, fit the spigot, bolt on the bracket. Done. We had to do some fettling, as I'd been very cautious with the bracket design and made it a tad tight... I.e. negative clearance
Do people want 302s or 314s? Be good to get an idea if numbers...Cheers, Torben
'94 B4 Avant S2Comment
Yeah this setup worked really well and a credit to Rusty's design it is as "bolt on" as you could hope
. I have 1 little mod to make on the prototype brackets on a manual mill just to tidy our fettling up and re-anodise. But once done i'll be fitting the 302mm option (silver discs in pics) and i'll be sure to put up plenty of pics from start to finish showing 16" and 17" wheels fitted, and show the side on comparison to the 314mm 996 fronts. It will be a perfect way of increasing brake performance and getting rid of our "mcvities" rear brakes.
"Difficult is worth doing"Comment
