Originally posted by s2avant95M
Lets have a mass debate on OIL
Originally posted by JamoThis has been covered on here, with Mihnea and a few others explaining the advantages. Other users like MikeS2 dont' agree as the thicker oil can allow for higher build up of oil temperature within the engine theorectically accelerating engine wear.
Ok, so no one is right or wrong. you pays your money, blah blah blah. i know its been discussed before, but i just wanted to try and clarify the position as the other threads are about 9 pages of people saying i put this type of oil in and others who put the other type etc etc.Tim
1995 S2 Avant, ruby red - ** SOLD TO ROSS **
Golf Rallye G60 ** SOLD **
Golf MK2 Oaky with R32 engine
Audi A6 Avant 1.9 TDi 130
Golf MK2 8v Race carComment
Yeh, It's very much like tyre choice, with people with difference preferences.Originally posted by s2avant95MOk, so no one is right or wrong. you pays your money, blah blah blah. i know its been discussed before, but i just wanted to try and clarify the position as the other threads are about 9 pages of people saying i put this type of oil in and others who put the other type etc etc.
The only "correct" oil would be the VAG oil in the manual in theory
My car hates 10/40W, it's been alot better on 10/60W although i would be prepared to try the 10/50W stuff.Comment
Hmm, tyre choice is more of a personal preference as to feeling on the limit and driving conditions. Surely oil is either good for the engine or not so good for the engine, personal preference aside. Though I can see how climate, driving patterns and even the individual engine may can influence the best choice, meaning that there is no sure answer... personally, the chemistry behind fully synthetic oils convinces me. I definitely don't want that oil film breaking in my turbo!
The car currently has millers; oil temps even on hard driving stay low, pressure about 1.8-2bar on idle and 4-4.5bar on the move.AUDI - saving Dad's from minivans since 1994
whenever you find 9 pages of opinion it is usually a sign that there is 'no right answer' as I have found out in the past while trying to get 'a right answer'Originally posted by s2avant95MOk, so no one is right or wrong. you pays your money, blah blah blah. i know its been discussed before, but i just wanted to try and clarify the position as the other threads are about 9 pages of people saying i put this type of oil in and others who put the other type etc etc.
For what is is worth my S2 coupe from 1997-2004 had mobil 1 0/5W/40 every 5k. I have experimented more with the RS2 Motul V300 5W40, Synta Gold 5W now 0W/40 and now Mobil 1 15W/50. Changed every 6K ish with new filter. Oil pressure always 2 ish on warm idle although at present the car seems to like to 'eat' 15-50 faster than 0-40 which is not ideal as I switched to reduce consumption. So watch this space for news...............Alastair
RS2Comment
I've seen two distinct theories regarding, in particular, the viscosity of the oil - for ease of discussion refer to the "thickness" of the stuff.
The thicker oils should provide more contact and coverage of moving parts, and tend to give higher working pressures. This may be good for older high mileage engines.
However, a lot of wear takes place during startup, and a thinner oil in these circumstances should be providing coverage and protection a lot quicker, as it gets to the moving parts sooner.
It may also be true that a higher oil pressure reading given by using a thicker oil is not really an accurate demonstration of the protection being afforded by the oil. I distinctly remember a feature about oil that stated "do not use thicker oil to get higher pressure gauge readings - fix the problem that is causing the low pressure in the first place".
I take that as meaning new bearings and the like.
For my two penn'orth I have used Magnatec 10-40 and I have even used GM synthetic, but to be honest I haven't been able to prove anything with either.
I am willing to hear any recommendations and supporting evidence though, seeing as I am about to embark into the world of higher bhp!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
Isn't the point of synthetic that the esters in the oil are controlled in manufacture, so the mix in the oil is much more "accurate" than in semi-synthetics, or the old-fashioned organic oils, ie the right things are in there? I don't see why you would want to not run a car on fully-synthetic oil?Ex S2 owner, now running around in an A4 Avant quattro...
Here some data:
Castrol RS 10W-60
Dichte bei 15 °C kg/m³ 849,5
Kin. Viskosität bei 40 °C mm²/s 177
Kin. Viskosität bei 100°C mm²/s 23,6
Viskositätsindex 163
Flammpunkt COC °C > 200
Pourpoint °C - 42
Mobil1 Rally 5W-50
Mobil 1 5W-50
SAE Grade5W-50
Viscosity, ASTM D 445
cSt @ 40º C104.9
cSt @ 100º C 17.5
Viscosity Index, 184
HTHS Viscosity, mPa·s @ 150º
Pour Point, ºC, ASTM D 97 -54
Flash Point, ºC, 236
Density @15 ºC kg/l 0.859 it means: 859 KG/m3
Silcolene Pro S 10W-50
Kinematic viscosity @ 100 C ..cSt 18.17
Kinematic viscosity @ 40 C..cSt 116.49
Viscosity index IP226 174
Specific gravity @ at 20 C 0.866
Pour point °C -32
Flash point, closed cup °C 210
So can someone tell how much worser is the M1 5W-50 than the RS 10W-60 in the High temperature area?Last edited by Billman; 19 January 2006, 08:48.Go Holset or Go RS4Comment
I use Synta Gold in mine.
176K.
Oil pressure at idle is 2bar and, running, in excess of 5 bar.
Always has been.
The first owner was **** about oil changes every 3K miles.
No idea what he used but the car obviously liked what he did back then and I guess I am reaping the rewards....
FWIW.00 Audi B5 S4 MRC550
08 RRS TDV6 HSE
03 Kawasaki B2 ZX12R 1287ccComment
Okay then here it is straight from the horses mouth. I know this guy ('cuse the pun) is well respected in the motoring community:
He sells all sorts of oils so has no reason to recommend one over another. I am *thinking* about changing to one of the 10w50's....
Email from Oilman:
Steve,
Thanks for the mail.
For your S2 we would recomend either the a good 5w-40 or 10w-50
synthetic depending on engine/oil temps.
If they rise above 120deg then look at a 10w-50.
The Castrol RS is sadly just a hydrocracked mineral oil, and is not as
good as its made out to be, if you want the best look at the SIlkolene
Pro S or the Motul 300v.
Regards
Guy.
Opie Oils
ORDER ONLINE at HTTP://WWW.OPIEOILS.CO.UK <http://www.OPIEOILS.CO.UK>
or CALL GUY or SIMON on 01209 215164
Silkolene, Fuchs, Motul, Mobil, Castrol, Amsoil, Brembo, Purolator
Filters, Denso Spark Plugs, Splitfire Gauges, DNX Exhausts and more.......The Perfectionist
Useful site. Spent ages getting a source of Motul 18 months ago. Lets see what they suggest given they carry a wide rangeOriginally posted by Fat Audi 80Okay then here it is straight from the horses mouth. I know this guy ('cuse the pun) is well respected in the motoring community:
Email from Oilman:
Steve,
Regards
Guy.
Opie Oils
Filters, Denso Spark Plugs, Splitfire Gauges, DNX Exhausts and more.......Alastair
RS2Comment
