Oil recommendations and questions here - The Definitive S2 Oil thread
Hi oilman, I was wondering if you have a recommendation for the best oil to use in a rear torsen diff?
(torsen type rear diff originally fitted to early '90's Audi 'V8' (D1 Typ 44) to be installed in an Audi S2 coupe).
These diffs can run very hot especially with track use (which will occur occasionally) so I believe that normally a heavyweight oil is recommended. . . specifically though I was wondering if you knew what type of Redline gear oil would be best in this application - one of their normal gear oils? (and what viscosity?) or their Heavy Shockproof Gear Oil ?
As the torsen diff works on friction between gears, would the shockproof oil be a bad idea because it is: ?
I wouldn't go for the Heavy Shockproof, my choice would be the Redline 75w-90 GL5 if the temps aren't silly, but if it's getting really hot, the Redline 80w-140.
Use the code S2F and get 10% Club Discount
oilman's website for BMW engine oil and much more - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Hy Tim!
Sry to bother!
For the running in an 20v turbo engine... what you think about the 10W40 Castrol Magnatec?
I hope will be ok for 500km...then..iff the engine is running fine i would like to switch to 10W50 Silkolene.
And...2 question...I have in an 20v turbo powered Audi v8 the Motul racing 15w50...
With oem oil radiator and, at outside temps over 30 degrees celsius..driving on highway at higher speeds...the oil temp starts to rise at almoast 120...the point where i slow down offcourse....is this ok for this oil..or i should change the radiator or oil?
Thank You!
Regards!
Eugen
The Magnatec is fine for running in and when it's ready, the Pro S is ideal.
120C is fine, that Motul is good for up to about 150C.
Tim
phone: 01209 202944
What is the benefit of ester-based oils? How does the Gulf Competition oils manage to Motul, Redline etc..? Was thinking of this http://www.opieoils.co.uk/p-60122-gu...-oil-5w40.aspx but do you recommend some other oil or other viscosity? We have quite cold winters here, but also hot summers. The car is used mostly on the road but also on trackdays. Valvoline SynPower 5w40 rises to 130C degrees on track, on higway road ~100-110C degrees.
Hi, I have made approximate 6000km with Castrol edge 10w-60 an they look pretty dark. Is it good? Should keep use them or go to something else?
Can you please tell me what is best to worst between:
Castrol edge 10w-60
M1 rally formula 5w50
Valvoline VR1 5w-50 or 10w-60
Shell helix ultra racing 10w-60
The edge is the best one, followed by the Mobil 1 and Shell. The Valvoline is pretty basic in comparison. It depends on how hot your oil is getting, but I would think that the Edge 10w-60 is too thick.
Tim
phone: 01209 202944
Ester based oils have a few advantages
1. Stick to metal surfaces, so they give better cold start protection
2. More stable at high temps
3. Better lubrication
4. Can help the car to run quieter
The Gulf is a really good oil and very good value. 130C is a bit high for the Valvoline, that's around the top limit for the ester based 5w-40s. I'd say the Gulf 5w-40 would be a good choice.
Tim
phone: 01209 202944
Tim
The engine has forged internals thats why I think that the 10-60 is good since at start up I have more clearance.
True, but I'd probably go for a 10w-50 rather than 10w-60.
Tim
phone: 01209 202944
I have a question. I don't know if it is oil related but my engine turned around roughly 60K miles mostly driven with 10W60 and 10w50 oils. It dropped compression and turned out to have mirror finish cylinders on inspection. Not only that, but the wear was such that a simple hone doesn't cure it and I am going to oversized pistons again.
Since my car is used everyday, has relatively low coolant temperatures due to lower thermostat and valves, and it does small and long drives on a daily basis, with occasional fast driven portions.
Can the cylinder wear be related in any way to the thicker based oil? Should I be using 10w40 or 5w40?
I can't be certain of the answer as to what has caused the damage. Is the car modified?
phone: 01209 202944
What would be the recommended oil change interval for a daily driver (20 000 km per year) with ester based oils like Redline or Gulf Competition 5W-40?
