Could it be that your car (when it was 136 bhp) did not have any form of oilcooler at all? I don't know what temperatures an S2 (3B) will run on circuits...
Oil recommendations and questions here - The Definitive S2 Oil thread
This is a sticky topic.
Originally posted by 1975DCSCould it be that your car (when it was 136 bhp) did not have any form of oilcooler at all? I don't know what temperatures an S2 (3B) will run on circuits...
@ Mihnea I like Motul v300 5-40w as per Simons recommendation except the car seems to be using it quicker than the previous Mobil 15-50w. Good fuel econ and smoother acceleration.
@Simon given the above facts (oil temp rarely above 100 standard RS2) should I stick with that Motul spec ?Alastair
RS2
I'm using castrol rs 0w40 on my S4 2.2t. Oil temp goes around 130C when driving 200km/h (outside air temp +25C). But i think that by problem is missing oil cooler airguide. But I think that it's a good oil. No "tick" in engine after accelerations.
Originally posted by PapVasif the oil temps are so low,maybe your oil temp sender could be malfunctioning.
On my previous Astra temps were very high at first but than it turned out it had an 50-150 sender, with an Audi 50-170 gauge...Last edited by 1975DCS; 18 October 2006, 22:04.
They are fine, the Esso will be fine. If it carries the Porsche approval its probably a PAO synthetic.
Simon.Use the code S2F and get 10% Club Discount
oilman's website for BMW engine oil and much more - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Can anyone tell me where I can get some Mobil 5w-50 ? It's proved impossible to find in Belgium...
To Oilman, when I bought my car, I changed the oil very soon after buying it for peace of mind and put in Esso 5w-40. The car ran fine ( stock engine at the time ) but in winter, the tappets were noisy on a cold start and if I started hammering the engine, the tappets would start ticking away again till I would leave the engine idling for a few minutes... Also, in hot summer weather, just cruising within the speed limit a long distance on the highway would show 110 degree oil temp and pressure would fall just a tad under 4 Bars...
Switched to Castrol RS 10w-60 on MRC's advice and all the tappet sounds went away and the idling oil pressure went from 2 to 3 Bars and oil temp doesn't change anymore just by normal driving ( winter or summer ) except if I'm racing on the Nurburgring where it'll settle at 110-120 degrees.
I've read your posts and I still can't make up my mind between sticking with the Castrol RS or switching to the Mobil.
As winter is here, I'd like to know what's best for my Avant....
My engine now develops 400bhp with a hybrid turbo ( see signature )
Help please ! Thanx !Midnight Blue S2 - SOLD - 1993 S2 Avant
