Can running the older spec oils like API SL cause problems with late model petrol engines? Say like with TFSI's? Problems like shortening the life of the cat converters or something similar like that, maybe expensive to fix later?
Oil recommendations and questions here - The Definitive S2 Oil thread
This is a sticky topic.
Hi
Yes, with very sensitive cats. Some can be really fussy, like some of the Fiat 500s need a low ash oil, normally only required for low emissions diesels.
TimUse the code S2F and get 10% Club Discount
oilman's website for BMW engine oil and much more - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Hi
I don't deal with Q8, so I can't really comment on their oil, but the Mobil is decent stuff.
The best option would be a 10w-50 ester based oil, like Fuchs Pro S or Millers CFS.
phone: 01209 202944
Hi
No, realistically I don't think it will get to you in time.
phone: 01209 202944
It's okay, but their Supersyn is one of their more basic synthetics.
phone: 01209 202944
Hey Oilman. I got offered a great deal for Mobil1 5w 50 Rally formula oil. What do you think about this oil? Winter is coming. Car is Audi 80 Competition 2.0 16v + turbo.Comment
Hi
It's a good oil, if you can get it for a good price, use it.
phone: 01209 202944
What oil do you recommend to use with e85 fuel? Have been using Gulf competition 5w-40. Engine bearings have been like new, but two turbos has failed.
BMW 740iA e38 - ProjectComment
Hi
I would stick with a good oil like the Gulf Competition, but what sort of power is the car making and how often are you changing the oil?
phone: 01209 202944
Two summers with 600+hp @2.5-3bar boost. Quite a lot of abuse on street, track and drag, oil used maybe 2000-4000km before change. Turbo failing can also be an oil feed problem due an4 linings...
But, your saying Gulf Competition is good to use with e85(ethanol) fuel?
Hi
I would have thought with that sort of power and use, a 10w-50 might be a better option, but that depends on the oil temp.
The Gulf is a really good oil and fine with E85 (as much as anything is), the issue with E85 is that it can cause fuel dilution, but changing at 2-4000km should mean that isn't an issue.
phone: 01209 202944
