Problem after upgrading to RS2 Specification
  • Can you get a wideband on it, just to make sure it’s not running lean?
    • yep I could.
      Will look into what is available in SA
      • I did replace the O2 sensor several months ago and the cars performance did not alter, does that not indicate the sensor is not the issue?
        Can a wideband sensor just replace the original OEM Bosch O2 sensor? or would it be used for display only?
        • You cannot replace it directly but for instance Zeitronox do a narrowband output with their wideband kit.
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
          • You can put the wideband up the tail pipe to check the fuelling is ok. Any normal dyno guy would do this for you.
