Ahh cool thanks for that Jamo... Now I know what im looking for when I get under the car
Quick 'how to' replace fuel lines
This is a sticky topic.
Fuellines
Just got a delivery of 7,5 m Cu-Ni pipe and an assortment of wadeconnectors, including T-pieces because i´m planning to use a fuelpressuregauge.
Have any of you thought about removing the fuelfilter from that horribly unattainable place and doing the feed pipe all the way up to the connector on top of the tank, and relocating the filter to a better place? I´m thinking of putting the filter somewhere closer to the engine?sigpic
80 quattro 1984..... S2 sedan 1994
Zermatt silver......... Brilliant black
guys,is it right,to use a rubber hose on fuel?Look at picture. Its from tank hole to fuel lines around fuel filter
Or is better to use a different types of fuel hose and clips?Fuel hoses what i used is dedicated to use on fuel ...Audi Coupe Quattro 2.3 20V
I think its OK to use rubber for short flexible pieces, I would use as much metal line as possible as it will not be damaged by stones etc hitting the underside of the car, i think rubber hose will deteriorate a lot faster. With rubber hose you should use the stuff with the cotton braiding to protect it
