Quick 'how to' replace fuel lines
This is a sticky topic.
checked the fittings today and was M14. I'll order them and see, all will be fine!
1994 Audi 80 - 2.0 8v (slow but reliable!)Comment
Very little - the lines arent holding significant pressure when engine is off - unlike old k jetronic machines that have a pressure holding valve. Take the usual precautions though !Paul Nugent
just pull the pump fuse when the engine is running mate, relieves all pressure before you crack the lines... if you are cutting them underneath the car you'll still get a fair old dribble though
Imola B6 S4 AvantComment
cheers guys - final question, what to crack them open with, any special tools? I have to do this i think before I head down to Le Mans this year. They look very cruddy around the rubber mountings and I have the MOT next week - I'm sure they will become an official cautionary item
1992 3b S2 CoupeComment
I used one of this small hose cutters that plumbers use - you need to pull enough of the pipe away from the clip to give it the clearance to travel neatly around the pipe. Give the pipe a good clean first in that area to reduce chances of any grit etc making its way into the pipe (apres filter). You gradually tighten the pressure on the cutting blade as you do a few laps of the pipe to get a nice clean break.Paul Nugent
Like MS125 on this page...... http://www.silverlinetools.com/products/d85/s686Paul Nugent
Thats the kind I used, nice and compact makes it easy.Like MS125 on this page...... http://www.silverlinetools.com/products/d85/s686
Sold ABY-stockComment
so picked up a silverline tool at the weekend, so just need to confirm how much pipe to buy and reconfirm the Pipe ID - anyone help?
As its on stands waiting for the rear subframe to be sorted, Might as well sort this one as was on the list of cautionary items at last MOT
Davidsigpic
Yep, just the runs under the floorpan to the point where they go up along the back of the firewall.
Is this kunifer stuff pliable enough to work with by hand or do i need a pipe bender at all. Not a job I want to start and then realise I'm missing something
Davidsigpic
