hi paul. you got a pm.
Have tried today getting the ecu out, but it cannot get past the white plastic clips and a mounting bracket for the fan ventilation i think it is
I didn't get a fresh PM from you... Strange. This problem is normal if the ECU has never been out before. Some patience and a strong back is required.
That white bracket twists off.
You generally need to remove the aircon drain pipe as well for improved access.
Lever off the 55-pin ECU connector carefully to give you clearance.
Then lever up the big spring clip and pull the ECU downwards from its location - there is another clip up at the top which is gripping the ECU, but with strength, dexterity and care you can pull it down.
The thing I also fight with is where a corner of the ECU snags the carpet on the way down and it gets jammed... Sometimes you need to trim the carpet a little bit.
Got it out now, but found out that the u-bent is broken off the ecu where the connector goes in, so have to fix that also
Lots and LOTS of smal stuff to fix
Hi Paul
Sent a pm to you last week regarding a homefry for a stock 1995 S2 ABY down under. Can you check your inbox and let us know if you can accomodate?
Karl
Oz
Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
Audi 90 Quattro 20V 1989 7A
Audi TTRS 2010 APR stage 2 +
Triumph 675 Street Triple R
