Best place to buy F5DPOR's
This is a sticky topic.
  • s2driveruk
    • 12696
    glad i asked now :shock: I'll order up a set of the FR5's I think.
    No issues for stock or lightly fettled 3b's before I checkout? Oh, and still running caveman ignition
    1992 3b S2 Coupe
      At that rpice, you can change tehm 3x more often if needs be
      • s2driveruk
        • 12696
        indeedy
        1992 3b S2 Coupe
        • Thuppu
          • 4115
          Originally posted by Avantus
          So are the FR5DP's also suitable for the stock coils, or do you need the 1.8T coils?.
          All I can say is, when I tested a set of FR5DP with my stock coils(1.7bar boost max) I got big cut outs at high boost. When I putted back the F5DP0R everything worked like sharm again. But later one coil did go bad, so it can be that it was symphtons of the coil going bad soon..?
          • prj
            • Mar 2010
            • 6308
            I did not have problems with stock coils.
            Maybe your coils were just going bad?
            @OP
            I know the NGK's that JP posted about work perfectly fine as well.
            You always have choice... a friend of mine used to use FR5DP's for a short time on his 3B without ill effects (but he went multi coil shortly after).
            • s2driveruk
              • 12696
              suddenly it feels less clear cut than before...is the FR5 suitable for non coil S2's or not..not wanted to trial and error on a new engine build - if they are not proven then don't appear mcuh safer than existing F5's
              1992 3b S2 Coupe
              • prj
                • Mar 2010
                • 6308
                Uhm, not safer? The porcelain does not break and fall into your engine because they are not "suited", it's because their manufacturing has gone **** up.
                Just try it, if you don't have any misfire, then they're suited, pretty easy
                If not, keep them for a multi coil setup. They worked on my friend's 3B for a month and on another friend's car with original AAN coils, can't comment on anything else.
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #23
                  really,i have never had a spark plug issue with original F5DPOR
                  • prj
                    • Mar 2010
                    • 6308
                    That's fine, no one has an issue with them until half the plug falls into the cylinder.
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #25
                      this would be pretty funny
                        What is verdict on which plugs to get now?
                        • prj
                          • Mar 2010
                          • 6308
                          NGK BKR-7EIX or Bosch FR5DP.
                          • merlin's S4
                            • Jan 2005
                            • 1539
                            The guys in the US swear by the FR5DTC.
                            • audinut
                              • Jul 2009
                              • 2195
                              i paid about 38 quid from ECP aprrox a month ago
                              NOT a car dealer! just an S2/RS2 enthusiast
                              • madpugger
                                • Sep 2007
                                • 1901
                                The problem happened fairly recently. Like they started getting worse 1 year ago or so.
                                It's like buying a lottery ticket nowadays. If you are lucky, all will be fine, if you are unlucky, you'll get engine damage because of broken porcelain.
                                This is why I am looking for a new block and piston!
                                NOT FUNNY AT ALL! Very expensive and time consuming
                                Le Mans 2012
                                Nurburgring 700
                                1995 S2 Avant
