Have you tried temporaily disconnecting the knock sensors at the bulkead to see if the ecu picks up a no signal fault for either or both.
S6 timing
Yeh, if you disconnect either of them the ca goes into the full on limp, limiting boost to 0.4 bar so it proves nothing. Some if you connect sensors up bolted up to nothing.Comment
If certain signals into the ecu fail then it uses certain fixed values. In the case of the knock sensors it is a retard which you claim is what you are experiencing.
But if you have unplugged them and the ecu goes to mechanical boost then we have to asume it is picking up the knock sensors.
So if it is not ignition then we are back to looking at fueling and temperature and their effect on the engine.Comment
G61/G66 Knock Sensor Information
I'm not sure if I agree about what the result of failing knock sensors is exactly. I agree that without a G61 or G66 signal, the ECU will pull the timing down by 6 degrees for their respective cylinders. However, I have never read anything (well, nothing that I rememberIf certain signals into the ecu fail then it uses certain fixed values. In the case of the knock sensors it is a retard which you claim is what you are experiencing. But if you have unplugged them and the ecu goes to mechanical boost then we have to asume it is picking up the knock sensors.
), that says boost is pulled to mechanical only, i.e. the WGFV is told to stand totally down. There are comments that boost pressure is decreased but no necessarily to mechanical. I could be wrong.
G61 and G66 Knock Sensor info: http://forums.quattroworld.com/s4s6/msgs/21047.phtml
This points to a sensor or wiring problem. When you disconnect the ecu it resets the adaptation, then you connect it again and drive on the basic map, all is well but quite quickly it adapts wrongly because of a bad sensor or a high resistance in the wiring (like the corrosion on the MAF connector) it basically adapts itself out of tune.Comment
Uhm, torque looks about right for a generic chip?
Can get more with a MAP sensor swap and different software...Comment
You don't want to go there. If you are concerned about a broken loom (BTW: OE AAN looms rarely, if ever, have an issue), use a multimeter set to Ohms and some long leads to check continunity between the engine bay device, e.g. IAT, connector and the appropriate pins in the T55 connector at the ECU.
Here is the AAN pin-out that you could use as a guide. It has wire colours and the appropriate T55 pins listed:
BTW: Do you know for sure that your cats aren't clogged, as in remove them and bypass them to see if there is a performance improvement?
I feel your understandable frustration from here, given how long this has been going on, years.
Find out when Prj is next coming over to England, and make an appointment with him. At this stage you've nothing to lose, and everything to gain.
Best wishes.
