Chaps I have been asked to get a partially restored UR running well. In short I am assured it starts but isn't happy revving up. I intend to start to by setting up the mixture and the ignition timing check for vac/boost leaks etc.
I have no experience of the B3 engines with the exception of a KV engine which I had a similar job on.
Can anyone give me a step by step or pointers. eg mixture figures and ignition timing figures etc. I cant find any information strangely. I believe the CO is to be set between 0.6 to 1.2 % with the lambda unplugged and up stream of the cat. So I assume there will be a sampling pipe on the manifold. I have also read about having plug a fuse into the ECU relay?? Although I could be miles off.
Any advice will be greatly appreciated. I have experience of the CIS systems to some degree. Thanks in advance Steven.
