Mark's Catch Tank
  • Doug_RS2
    • 3847
    #91
    If you want to tap a hole into the sump, I have mine sitting off the car in the gargage - I could see if there was an appropiate place to tap it as there are fins on the inside.
    Actually that might be a bad idea - you don't want filings in the oil. Taking the sump off for that is a PITA - best to get the fumoto or tap the sump plug - I think Mark has done that on his.
    HTH
    • sal_s2
      • 1288
      If the fumuto valve is open, wont the oil from the sump go up the pipe into the catch tank, or have you got some sort of 1 way valve also?
      • Doug_RS2
        • 3847
        #93
        The oil is picked up from the sump - it's not under a lot of pressure there. I thought I would have to have a one way valve but it was fine without it. You can always have it closed - then you can check how much oil it is catching. THe Mocal tanks have a clear tube up the side to see how full they are.
