Climate into RHD avant
This is a sticky topic.
  • rj scotty
    • May 2006
    • 2195
    #31
    Sun light sensor is intact
    I defiantly do not have C13 the space in the connector is empty
    I have left the ccu off for a long period of time with some random settings and appearers to retain them, it seems strange to me that there is no permanent 12V.
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • johne
      • Apr 2007
      • 1406
      I defiantly do not have C13 to space in the connector is empty
      I can understand that it can remember last settings without power using modern flash memory but not how it could calculate engine standing time without power.
      John
      • rj scotty
        • May 2006
        • 2195
        #33
        looking at the diagram again now
        Could it be D9 on this controller is a permanent 12v feed ?
        cheers
        rich
          #34
          C13 exists as unswitched 12V (terminal 30) on the MY96 A4 schematic
          But it does not feature for MY97 or MY98 - instead the supply is a switched feed on a black/red wire that lands on pin D9 of the head unit.
          Pin D9 on the MY96 wiring has a completely different purpose with a connection to F73 (refridgerant low pressure switch on the evaporator) so be careful like I said to ensure everything lines up.
          • rj scotty
            • May 2006
            • 2195
            #35
            no it's switched
              #36
              Guess the later head unit relies on NV memory for whatever it has to store and doesn't require the permanent 12V feed
                #37
                I am looking at My97 and 98 diagrams right now - there is no permanent 12V supplied to the head unit.
                I've captured some tables of info here - saad man that I am about wiring... will endeavour to formalise it and compare / contrast the two systems.
                • rj scotty
                  • May 2006
                  • 2195
                  #38
                  beat me to it
                  still strange no 12v permenant
                    #39
                    So I say again - do not trust the russki dagrams... they are close but not perfect.
                    • rj scotty
                      • May 2006
                      • 2195
                      #40
                      This is strange johne's chart shows D9 as a 12V x load dump (I know what x load is now thanks to s2central ) and that his is an earlier controller.
                      Really Appreciate the input guys
                      cheers
                      rich
                      • rj scotty
                        • May 2006
                        • 2195
                        #41
                        Another silly question where dose J153 live on the S2
                          #42
                          Now I'm normally pretty hot on all those relay positions, but gimme a clue on what J153 is here .
                          • rj scotty
                            • May 2006
                            • 2195
                            #43
                            J153 switch unit for magnetic clutch
                              #44
                              Surely you mean J44 - that is Aux position 4 in the S2/RS2 with climate - common to B5 platform as well - I mean the J44 label of course.
                              • rj scotty
                                • May 2006
                                • 2195
                                #45
                                It's labled on the diagram as J153 but has a number 4 in a black rectangle next to it it has 8 conections.
