Clutch slipping
  • audiman
    • 4827
    One new clutch installed and NOT slipping. Result!
    In the end i have a standard clutch, with a modified cover plate to give increased clamping pressure! It was the best they could do as Mr. Helix just couldn't supply in time. Will know for next time to order in advance.
    Let this be a warning to you all! If its needed, ORDER IT UP. It could take upto a week to produce the goods.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
      Tom, have you got details of the uprated pressure plate you mention in the previous post? I thought I was getting one but now I've been told I've a stock clutch in there as there was no uprated one available, like you I didn't want a paddle job. So now I'm stuck with the stocker.
      Ta.
      • *ZenithalRavage*
        • 216
        Originally posted by audiman
        Gonna have the wastegate pipe made up at the same time, whilst the downpipe is off!! Should sound mental then.
        Originally posted by Sweeper
        Tom: What is the advantage of external westgate pipe ? Apart from super noise
        Where that external westegate pipe connected to ???????? I just don't get it . Mark have it , but i don't see where it coming from.
        This external wastegate pipe mod sounds very interesting. If any of you have pictures & more info on this I would really appreciate it.
        Do I understand correctly that this mod will release boost pressure to the atmosphere?
        If so, won't it affect the mixture (richness on throttle release?)
        How does the sound compare to a ricers blow off valve?
        grtz
        *ZR* S2 R.I.P.
        Visit *ZR*'s Hideout!
        • audiman
          • 4827
          John, the cover plate was made for me by a local firm. PM me for details and i will give you there phone number.
          And the wastegate pipe....... its nothing like a rice racer valve! it releases the gases from the wastegate to the roadside and not back to the downpipe!
          Audi UR Quattro
          • S2 Ant
            • 3682
            how is that mod done as i cant see how you would do it....
            i presume its not an expensive thing to do??
            Ant
            2011 Kawasaki Z1000
            • Mark Halligan
              • 2001
              Ant,
              if your still getting Clive to make your exhaust at Prism he'll do it for you, here's the one he did for me. Mind you I'm going back for a small silencer to be put on it soon, bit too fecking noisy when on boost for me :eek2: .
              Mark.
              Mark - Modded
              • audiman
                • 4827
                Ah, those poor OLD ears! :nana:
                In the process of having mine done!
                Audi UR Quattro
                • S2 Ant
                  • 3682
                  does it require a custom downpipe be made for this mod to fit??
                  Ant
                  2011 Kawasaki Z1000
                  • Mark Halligan
                    • 2001
                    LOL, nice to have you back young Thomas .
                    Ant yep, I forgot you are having the sysyem built from the DP back are'nt you? Could still be done to the old one though, I would have thought.
                    Mark.
                    Mark - Modded
                    • *ZenithalRavage*
                      • 216
                      Originally posted by Mark Halligan
                      Ant,
                      Mark.
                      wow, that kinda looks funny
                      Does it sound similar to an open loop blow off valve?
                      *ZR* S2 R.I.P.
                      • Mark Halligan
                        • 2001
                        It sounds like open headers, which is what it basically is. It only operates when the engine is on boost and the wastegate opens, not to be confused with a dump valve.
                        I am hoping that the silencer soon to be fitted will 'sweeten' the sound and make it less raw, should still spit the odd flame or two though .
                        Mark.
                        Mark - Modded
                        • audiman
                          • 4827
                          Oh yeah, the flame pipe LOL
                          Audi UR Quattro
