Propshaft Overhaul
  • Skull
    • 3506
    • Country: Slovenia
    #181
    just read the posts above, everything is there...
    Audi Quattro WR
    • RAOUL
      • Sep 2003
      • 260
      Hi Skull. I realise that I wondered if anyone in the UK had managed to find a UJ, my search for the GKN part draws me to 1 on EBay in the States. 👍🏻
      I think my prop has to ground out to remove the UJ, from memory they don't look like circlips! 😔
      ATB
      RAOUL
      • RAOUL
        • Sep 2003
        • 260
        Good news (maybe) gents, I've secured a Lobro U741 joint from IMS-LTD.CO.UK
        The joint was a lot less than previously quoted, in came at less than £24 posted.
        I hope this helps the masses?!? 🍻👍🏻😎😁😉
        Regards, Raoul. 🍻👍🏻😎
        ATB
        RAOUL
        • RAOUL
          • Sep 2003
          • 260
          Does anyone know if all the coupe quattros share the same propshafts? I'm going to buy a spare to rebuild for ease.
          Many thanks.
          ATB
          RAOUL
            My turn to do the propshaft after one of the CVs kaked itself. Sounded like something was hitting the exhaust as it was a metal ringing noise from where the shaft was transferring the noise of the backlash on the joint.
            New joints, a lick of paint, full inspection and maybe a balance...
            • hunker7
              • Mar 2014
              • 3487
              #186
              Is the knocking anything like this?
              '93 Audi UrS4 Avant
              '15 Audi A7 quattro 3.0 TDI
              • s2driveruk
                • 12696
                Just to update on this one, I ordered a new UJ today from IMS-ltd.co.uk for £50.40 shipped. We cross checked the GKN 12111 and the Lobro U741 and this is the same, centre-lubricated 26x69.80 UJ that is compatible with (my) 3b propshaft if retained with circlips rather than crimped ends as ome of them have. I'll post up pictures once it arrives tomorrow.
                1992 3b S2 Coupe
                • sal_s2
                  • 1288
                  I'm after a centre bearing for the prop. Are people still using the bmw item? Anyone tried the ones advertised on ebay?
                  • 90quattrocoupe
                    • Nov 2003
                    • 771
                    Since I am in the states, I use this one. Powertrain Industries Center Support Bearing - #2580-10
                    https://www.powertrainindustries.com/story/2580-10?catalog_table=center_supports&make=Audi
                    Since you are in Europe, you may want to take a look at this catalog. The BRG.A1 looks to be correct for the Center Support Bearing. Doesn't seem to want to load using link.
                    Greg W.
                    • 90quattrocoupe
                      • Nov 2003
                      • 771
                      There is a Propshaft rebuild thread here.
                      • sal_s2
                        • 1288
                        Thanks for the help, ims are based in birmingham so local to me
                        • 90quattrocoupe
                          • Nov 2003
                          • 771
                          Let us know if IMS, has the correct bearing.
                          Greg W.
                          • sal_s2
                            • 1288
                            Greg, IMS have the brg.a1 in stock for £63. Is the baering height correct at 44.5 ? Some of the ones on ebay have a higher number for this
                            https://www.ebay.co.uk/itm/AUDI-80-9...G/141367728891
                            • steve briance
                              • Aug 2014
                              • 1455
                              Watching with interest... I fitted the BMW one a while ago now and am looking to change it. It doesn't seem up to the job as after what was only a few months, mine started whistling when cold... But only between 28 and 32mph!
                              • 90quattrocoupe
                                • Nov 2003
                                • 771
                                I don't know for certain, because the bearing is on the car. I noted the BRG.A1, because it has the funny kink in it that the oem Audi one has. I also don't know where IMS took measurements from.
                                The one you linked to ebay is not the right one. This is the picture I have of the old one and the new one from Powertrain.
