What measurement do you need Sal? I have a prop here I can measure
Propshaft Overhaul
Isn't someone on the forum supplying the OE prop bearing, at least a few years ago?
Was it GT500 or something?
I could be wrong though.Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
http://www.garaget.org/?car=52877Comment
https://www.ebay.co.uk/itm/114262224447
So Ive ordered the above, looks to be correct from the pics and measurement. I'll let you know once it turns upComment
I just want to mention a couple of things:https://www.ebay.co.uk/itm/114262224447
1 in the picture of the CSB you posted, the bearing does not look centered, it looks offset.
2 this seems to be an ebay only company, with no other internet or physical location. Just beware.
3 I would remove the seal from the bearing and take a look at the type and amount of grease in the bearing itself.
Just some thoughts.
Greg W.
They can have my car when they pry my cold dead fingers from the steering wheel.Comment
Bearing arrived and I've compared it with an oe ur quattro one and the aftermarket BMW part fitted to my aby prop.
Qualitywise it feels much stronger than the bmw aftermarket item. The metal frame is of the same gauge steel and size as the genuine Ur Quattro one.
However the shape is different. The genuine Ur Quattro one doesn't have the wiggley bit but from memory I think the s2 version does? 20200622_205240.jpgYou do not have permission to view this gallery.
This gallery has 1 photos.Comment
Something to ponder. I have taken apart B2 80Q, CQ and B4 sedan propshafts here in the states. The all had the "wiggley" bit in the center support bearing. I have also taken apart a range of propshafts that had replacement center support bearings, that ran a range of different styles.
Your UrQ propshaft may have already had a CSB replacement. That may be why they don't match.They can have my car when they pry my cold dead fingers from the steering wheel.Comment
I think i ordered this one https://www.driveshaftparts.co.uk/in...roduct_id=1751
was beefier than the bmw bearing, similar to the OE. Only thing i seem to remember was the kink on the support bar was the other side once fitted to the prop itself. I had a homemade alignment tool so i know it went on straight. No issues to date.sigpic
1992 3b S2 CoupeComment
I'm pretty sure its original as its quite worn and the rest of the car was original also when I got it, having only had 2 previous owners to me. I'm going to fit it this week anyway, quality and fit-wise it seems bang onSomething to ponder. I have taken apart B2 80Q, CQ and B4 sedan propshafts here in the states. The all had the "wiggley" bit in the center support bearing. I have also taken apart a range of propshafts that had replacement center support bearings, that ran a range of different styles.
Your UrQ propshaft may have already had a CSB replacement. That may be why they don't match.Comment
Looks identical DaveI think i ordered this one https://www.driveshaftparts.co.uk/in...roduct_id=1751
Shame they havent got any in stock, cheap price
Just realised, its actually the same place where I got mine from
happens to us all
