Propshaft Overhaul
  • s4kido
    • Aug 2009
    • 251
    • Home: Poland Current: United States
    #211
    Just resurrecting the thread.. I need to find a u joint for my audi s2 aby 6spd propshaft.. im located in usa.. can anyone help me find one??
    • Bowie69
      • Nov 2013
      • 2675
      For the others doing this, I ordered this one, and it fits great:
      https://www.ebay.co.uk/itm/114262224447
      Here's a screenshot of the details, including the size measurements, which I found handy:
      • s4kido
        • Aug 2009
        • 251
        #213
        I measure the u joint and the caps diameter is 24mm... where can I get a new joint?? Mines was crimped into place...
        • Bowie69
          • Nov 2013
          • 2675
          This was the one I used:
          https://www.ebay.co.uk/itm/114148117175
          Denoted as: 26 x 69.8 Propshaft Universal Joint Fits Mercedes / Audi - NEW
          Though mine was held by circlips.
          If you are sure of your dimensions, you can search just by them on ebay and find stuff. e.g. https://www.ebay.co.uk/itm/HARD-CAP-...IAAOSwjv5eoCek
          (not likely to be the right other dimension!)
          • SteveH
            • 4460
            I'm just about to get my propshaft shortened and balanced. Has anyone tried these CV's - https://www.ebay.co.uk/itm/New-Genui....c100752.m1982
            They look correct for the job.
            91 Modded 3B
            14 A6 Avant Black Edition
            • s2driveruk
              • 12696
              Got the right boot for the prop so thats a good start too!
              1992 3b S2 Coupe
              • SteveH
                • 4460
                I bought a new support bearing too. The Febi item I have on the prop is nowhere near as solid as the replacement.
                91 Modded 3B
                • s2driveruk
                  • 12696
                  Which did you go for? Yeah that febi one was always pretty flimsy
                  1992 3b S2 Coupe
                  • SteveH
                    • 4460
                    91 Modded 3B
                    • s2driveruk
                      • 12696
                      Yep, i have the same, its nicely substantial
                      1992 3b S2 Coupe
                      • SteveH
                        • 4460
                        I've just arranged to send my propshaft to Bailey Morris in St Neots to be chopped and balanced. Chards in Bristol have some poor reviews and the guy wasn't helpful on the phone.
                        91 Modded 3B
                        • adampug11
                          • Sep 2017
                          • 85
                          Sorry to bring up a old thread. I know Lobro 301142 are the CV’s I need but is there a kit with the boots included available ? Rather than buy the GKN ones separately.
                          cheers
                          Adam
                          • Bowie69
                            • Nov 2013
                            • 2675
                            I looked, but bought separate in the end.
                            • steve briance
                              • Aug 2014
                              • 1455
                              Propshaft cv joints, bearing and uj all ordered, shaft split down so its all now ready to go on but, noticed the boots are past their best and each have a small hole ​​​​​​
                              I see the GKN 'aero cv boot' looks suitable as it has the correct dia, hole pcd and overall shape but... Says it is for a 22mm shaft. Measuring my prop shows it is 26mm. Q For those swapped their boots; will the gkn rubber stretch 4mm?
                              Seems a lot...
                              • Bowie69
                                • Nov 2013
                                • 2675
                                I used these exact boots, all fine, note dimensions stated in the subtitle:
                                https://www.ebay.co.uk/itm/372564892590
