Propshaft Overhaul
  • GT500
    • Jun 2006
    • 2181
    I think it cost about £250 for all new every thing.
    Jamo, powerflex diff mount yes, gearbox? I didn't know they did them? Audi specialists are just fixing a problem,they no **** all about rubber grades/bearings. you drive away with a "fixed" problem. They only fit parts,Audi specialist not propshaft specialist.
    The way I look at it is, I Know my business. And I would hope you all know yours. These feckers ,all they do is proshafts. Thats it they don't fix cars,service, nothing just shafts!!
    He showed me the book of center bearings,,, it was thicker than a phone directory!! thousands of em, if any old thing as long as it fits will do surley they wouldn't be so many needed?
    The proper bearing was the similar price to the Bm one. It was more hasstle to them to get the Audi bearing.
    I am only trying to give you fellas a bit of info I got.
    take it or leave it..
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • Mark Halligan
      • 2001
      Fair enough, thanks for the good info.
      Do you have the part # and manufacturer for the bearing they used on your prop? Would be useful for anyone here wanting to service their own propshaft in the future.
      Mark - Modded
      • GT500
        • Jun 2006
        • 2181
        Best would be to send them a mail or give them a ring.
        Ask for Chris, he will help out with any request.
        If the Audi one is available why buy a Bm one?
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • s2dude
          • Nov 2005
          • 1631
          I couldnt find the PN but this is the part and where you can get it (quattronics may stock them? corey?)
          • GT500
            • Jun 2006
            • 2181
            Thats not the Audi one.
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • s2dude
              • Nov 2005
              • 1631
              Audi 4kq/80/90/Coupe Driveshaft Support Bearing
              And you know this how?? 034 EFI know a LOT about these cars.....
              • GT500
                • Jun 2006
                • 2181
                because it has the spinderly legs, not the thick quality Audi item.
                Compare it to the broken oem one in the first post of this thred.
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • Azman
                  • 3205
                  Ahem, Going to ask a silly question, Is there an easier way to get the propshaft off the car, Currently the car has no wheels or anything on other thant he subframes and gearbox. How do I get teh prop shaft off so I can remove the rest. The heatshield is off already just can't seem to get the thing detached from the gearbox or rear diff.
                  Dark Grey Avant
                  RS2 FARB
                  Alloy Subframe Bushes
                  • s2driveruk
                    • 12696
                    about to tackle this myself, what do you mean you cant get it off.....bolts fused on or.? I was expecting to have no problem getting it off, sounds like its not the case....gulp
                    1992 3b S2 Coupe
                    • Azman
                      • 3205
                      Just can't get the bolts started, but there is no weight on the system i.e. wheels etc to make ground contact...., time for a bodge me thinks!!!! Unless anyone has any ideas???
                      Dark Grey Avant
                      RS2 FARB
                      • GT500
                        • Jun 2006
                        • 2181
                        If you are struggling to hold the shaft, try a oil filter strap wrench around it. Bolts aren't tight usually,,
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                          Ah Azman do you mean because you have no wheels on the car theres nothing taking the load at either end of the prop so when you turn the bolts the prop also turns?
                          • s2driveruk
                            • 12696
                            did anyone ever confirm if it was the front or rear ford scorpio cvs that fitted up to the propshaft? i search a few times and they were mentioned but to that question seems no response.
                            1992 3b S2 Coupe
                            • Azman
                              • 3205
                              Nail on the head Jamo
                              Dark Grey Avant
                              RS2 FARB
                              • s2driveruk
                                • 12696
                                did you get it off the car in the end....also any tips on geting the U joint off the shaft?
                                1992 3b S2 Coupe
