Originally posted by Jonas_R
View Post
Project 450 - Will it be enough!
Originally posted by sjw185 View PostWhat you doing with your VDO EGT gauge? Maybe take it off your hands if you dont need it
Installed my 3" exhaust cutoff valve
So got my exhaust cutoff valve mounted last night.
Here is the solenoid valve that controls the Garrett actuator.
However I have some weird problem that is either related to my new spark plugs or my new fuel pump relay kit from 034motorsport. When I start the engine it cranks like 8 times before it starts. And now it cut outs everytime i try to put some boost on the car. Really strange I guess.
det er jo top dollar
but why the 90´ bend on the valve??
if you free then come too our club golf meet the 11-12-13sept. at padborg park
you can get some laps on the track
ill be at the entrence as always.
maybe take some from the audi dk club with you
90 degree bend on the valve?
Do you mean the exhaust or the solenoid valve? The exhaust has the 90 degree bend to get the exhaust gas down in the ground and solenoid has the angle or else it could not fit.
I need to get my boost sorted before I can attend, but I dont really do track days
Originally posted by Jonas_R View PostHowever I have some weird problem that is either related to my new spark plugs or my new fuel pump relay kit from 034motorsport. When I start the engine it cranks like 8 times before it starts. And now it cut outs everytime i try to put some boost on the car. Really strange I guess.
Should you earth your HO coils on the body/chassis? Maybe earth them on the engine instead. Just a thought.....
Originally posted by Bram View PostShould you earth your HO coils on the body/chassis? Maybe earth them on the engine instead. Just a thought.....
Problem came after I change spark plugs and added the fuel pump relay kit. That is the longer cranking and the boost cut off. Somehow I think it is related to the fuel pump relay, just can't see how. Unless the relay it self suddenly turns off because it draws to much current or gets to hot? I mean under fuel boost the pump will be using the most current and thus perhaps the relay is cutting off.
Something is off anyhow.
Originally posted by Bram View Postyes, that makes sense. Did you also put in a fresh fuel filter? Maybe that one got 'blocked' by the removal of the old one with some stuff
Bearings for 430hp / 600 Nm?
I'm right in thinking that for my 430 HP / 600 Nm project I can use RS2 purple bearings for the upper and lower part of the conrod?
Also RS2 bearings for the crank shaft right?
