Project 450 - Will it be enough!
  • pixsaudisex2
    • Sep 2004
    • 3110
    #301
    HERO.....
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #302
      i see you have used the 1.8T air temp sensor. that is not a bad idea! i might have to do that in the future
      • Jonas_R
        • 3780
        • Country: Denmark
        #303
        My gearbox is fooked at the moment
        Just bought a 6-speed on ebay, but I dont think it will be ready to drive anytime soon.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          #304
          Originally posted by pixsaudisex2
          HERO.....
          wich is this lovely thing???
          it is for open it and then going with FREE EXHAUST and awesome Rally car sound???
          Jonas, wich kind od 6 speed gearbox did you bought'? from ABY?AAN? later RS2 CRB code??
          • RIX
            • Jul 2004
            • 229
            • Country: Denmark
            #305
            what about the altea is it running again???
            just come itll be fun promise
            • Jonas_R
              • 3780
              • Country: Denmark
              #306
              The lovely thing is a 3" 90 degree bend that lets out the exhaust under the car. It opens over 1 bar and 4000 RPM.
              The 6 speed is a CGR from an ABY, it has 150.000 km on it. I dont now from what year it is from, but I might get lucky and get a late model with the wider first gear. But honestly I dont care, I dont really do 1/4 mile etc. So not that worried about the first gear.
              • Jonas_R
                • 3780
                • Country: Denmark
                #307
                I'm selling the Altea and I'm getting a Suzuki Swift 1.3 DDIC instead. But yeah it is running well
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #308
                  and before install the ABY box,will you check it inside for rebuild complete?? for take the box for a longgggggggggg time new for your car
                  about the 90 degree bend.... that it is mechanical?? or electronical controled??
                  and what about the sound....???
                  • Jonas_R
                    • 3780
                    • Country: Denmark
                    #309
                    No plans for rebuilding the 6speed, I dont have the money at the moment.
                    Well it is controlled mechanically and electronic. The actuator that opens the butterflyvalve needs to see around 0.9 bar before it starts to open. However to avoid it creeping open. There is a solenoid valve which my eboost2 controls. Which means that the actuator wont see any boost before 4000 RPM and 1.1 bar of boost.
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      #310
                      So 1½ days work and I got my new Sachs clutch fitted and also fitted my new (used) 3B flywheel (thanks Steve).
                      I actually found out that the previous owner have installed a Dual Mass flywheel for some odd reason. So that is up for grabs if anyone needs it?
                      Looking forward to some better weather so I can have a go with the VEMS unit
                      • Acidburn
                        • 13459
                        Just out of interest what box was that running with? a 5 speed or 6? and was there the spacer in between the box and engine?
                        look forward to hearing how you get on with this.
                        • Jonas_R
                          • 3780
                          • Country: Denmark
                          #312
                          Before I fooked the gearbox a couple of years ago I used a standard S2 5 speed gearbox. When I had the gearbox rebuild they slapped on a gearbox from A4 1.9 TDI quattro and used some of the internals from the S2 box.
                          So no spacer but a clutch from a Audi 100 V6 2.8. Anyhow I have a 6 speed S2 avant gearbox that I want to put on the car, was supposed to go on when I did the clutch and flywheel but due to time I have to but A4 1.9 tdi box on again.
                          • Acidburn
                            • 13459
                            Thanks for the reply, I was just curious as I have a engine running the duel mass flywheel/clutch/spacer on a 6 speed box but wanted to know if a 5 speed will bolt up and work fine as I prefer the ratios.
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              #314
                              So got my new 6 speed fitted and I'm almost ready to get the car running. But it was a lot of work fitting the damn gearbox. Had to remove proten, had to adjust the exhaust etc. But now it is good to go.
                              • Rocco
                                • Aug 2007
                                • 6393
                                • Country: Spain
                                #315
                                nice one Jonas..
                                whem you test it share your first impressions
                                how many hours of work are required for do the conversion?? 6? 10?
