jonas,will that be operating depending on temperature of the intercooler or the ambient temperature?
wouldnt it have been easier to just rig a switch to turn it on and off?
It uses ambient temp, and intercooler core temp and also duty cycle to decide when to spray.
However also thinking I will rig it up so that I can activate it in the doorhandle using a switch. I got a doorhandle with room for for window contacts. Right know I got left and right window control and also got a control to unlock/lock the doors. Then one more to start spraying
Was on a RR today, think the results are ok 350 Bhp and 420 Nm. The Nm are so low because the boost comes in way to late, only see just around 1 bar at 4000 RPM, think that should be closer to 1.5 bar. So Iam going back to Sweden very soon to get this sorted
This was without water injection and with a room temperature of 29 degress.
No I have not mounted the 034 coil yet, Iam looking into some different options at the moment. I got a wiring instructions from 034motorsport if you like?
My coil has some cracking in the epoxy and was thinking about replacing it with one of these. Would this be good to use? Is the 3b one of the Motronic systems that has the low output driver?
http://www.034motorsport.com/product_in ... cts_id=277
Reason: Motorgeek link
Leif-Helge
-91 S2 VEMS and Comp Turbo
-12 B** 530XD Touring "S2 parts transporter, and daily driver"
Jonas, looks excellent. Exactly the same place I mounted my amp also. I looked at placing the sub there too but hadn't done anything with fibreglass before so we for a wooden MDF one instead at the time.
