Project 450 - Will it be enough!
  • jonas,will that be operating depending on temperature of the intercooler or the ambient temperature?
    wouldnt it have been easier to just rig a switch to turn it on and off?
    • PapVas:
      It uses ambient temp, and intercooler core temp and also duty cycle to decide when to spray.
      However also thinking I will rig it up so that I can activate it in the doorhandle using a switch. I got a doorhandle with room for for window contacts. Right know I got left and right window control and also got a control to unlock/lock the doors. Then one more to start spraying
      Sleeper S2 Avant +450
      A6 Avant 2.7t Stage 3
      Audi S2 Coupe RS2'ed
      • Was on a RR today, think the results are ok 350 Bhp and 420 Nm. The Nm are so low because the boost comes in way to late, only see just around 1 bar at 4000 RPM, think that should be closer to 1.5 bar. So Iam going back to Sweden very soon to get this sorted
        This was without water injection and with a room temperature of 29 degress.
        • nice results.in a RR if you spray water as well,it will give you more power for sure.
          • Yeah Iam pretty satisfied with the result Just need the boost sorted and then Iam off flying
            • very nice mate!
              keep the good work
              • Updated my sub install today
                Decided to update my sub install and get some more room in the trunk:
                Made two 23mm MDF plates and mounted them where the spare wheel normally is. I decided not to make a glas fiber enclosure.
                Well here are the results:
                Amp is mounted in the small room in the back.
                Sub is cover by the carpet in the trunk:
                • Hi, did you use the 034 coil you mentioned earlier? And if so, did it work well, and how did you wire it?
                  Seems like a nice upgrade for a 3B (having said that, I don't know how high voltage the original produces.. )
                  Leif-Helge
                  -91 S2 VEMS and Comp Turbo
                  -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                  • No I have not mounted the 034 coil yet, Iam looking into some different options at the moment. I got a wiring instructions from 034motorsport if you like?
                    • Jonas i'm drooling over your sub!!!!!!!! Me want one they are so damn sexy
                      • Jamo: Thanks mate, it plays really well to
                        • Wiring instructions from 034motorsport:
                          Pin A: Green/White ECU Trigger
                          Pin B: Brown/Red Ground
                          Pin C: Brown/Red Ground
                          Pin D: Brown/Red Ground
                          Pin E: Blue/Black +12v
                          • Nice work Jonas
                            S2Forum.com Administrator
                            • Thanks Jonas! Do you know the voltage output of the original coil, compared to the 60-100 kVolts from the 034 unit?
                              Found something here:
                              http://www.motorgeek.com/phpBB2/view...t=uprated+coil
                              Leif-Helge
                              • Jonas, looks excellent. Exactly the same place I mounted my amp also. I looked at placing the sub there too but hadn't done anything with fibreglass before so we for a wooden MDF one instead at the time.
