Project 450 - Will it be enough!
  • Thanks Clive, now I just need to check that there are no oil/water leaks anywhere and recheck all the nuts and bolts just to be safe
    And then I can get the car mapped, aiming at the 1 or 2 of November.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • cool
      great work there, good to see it start so well and easy up
      japanischer industriabfall nein danke!!
      www.rackeltrim.se Icelandic Division
      • Update
        So decided to make some kinda heat shielding for the connectors that controls the trigger signal for the coils.
        Used a KN power blanket and then I had to use my arts and craft skills
        And here is shot with the heat shield blanket thingy
        Also made the new Turbosmart Solonoid ready for installation. However I do need some new fittings for the valve since the current hose nipples only accept 5mm hoses, kinda crappy.
        Made a small bracket that holds that valve in place:
        • Looking good!
          • Nice work on the AAN-mod.. What did you use as input for the G40 (Hall sender)? The 3b distributor ?
            '91 Audi S2 Coupe
            '85 Audi 80
            • Yup I used the 3B distributor works like a charm
              • Finally got some work done
                Finally I got my timing belt changed and replaced the lower CAM sprocket with one from Faheemo.
                Also got my new Zeitronix multigauge installed so it can show boost, egt, afr, lambda etc.
                My new wagner ic arrived just need to install it.
                Couple of shots of my WI looking forward to spring so I can see how effective it is.
                Also installed Maxqdata and bought a G-rays 10Hz gps. So i will do some 0-100, power measurements etc when the weather gets better.
                • Did you get your car mapped?
                  • Well I need to get the boost done 100% right know it is not perfect because of a timing error while we where mapping the car.
                    • Sweet!
                      • Update
                        Wagner IC is now installed, will take some pictures soon.
                        RS2 IM - Bought a RS2 IM from Jamo and it arrived today, nice Need to get it installed.
                        Considering removing my aircondition since it aint working and has not been for a while. I dont want to spend the cash on fixing it.
                        My idea is to remove the condensator, the climate compressor and piping.
                        I would leave the blower and the digital control unit in, so that I can still control airflow if this is possible?
                        I'm a bit unsure if this would work, just removing the aircon parts and the using the system as a non aircon system?
                        Any btdt or suggestions?
                        • Glad it arrived o.k
                          • Couple of pics of the Wagner IC installed:
                            The RS2 IM:
                            • Some progress with the RS2 IM
                              So got some work done on the car with the RS2 IM.
                              When I had it off I discovered that the bracket that holds the dizzy was loose. Pretty nice find since this turned out to be way I was having boost cut at high RPM's.
                              Got a stud welded on the IM and made a new bracket for the fuel pressure regulator:
                              IM installed, still some work left:
                              The RS2 IM moves the location of the TB, so had to cut and reweld the intake pipe. I added to 20mm pieces:
                              Actually the TB is also higher so it aint possible to use the old mounting points. So instead I welded on a bush, that fits over the threaded pin.
                              Also had to cut and weld the cruise control bracket to get it to clear the dizzy.
                              • Wow, that's quite some fixes to be made once you swap to a RS2 IM from a 3B IM. While you are there you could also alter the route of this silly fuel line hoovering over the RS2 IM....
