My Ocianic Blue Ur restoration
    Originally posted by Tractor Dave
    Cheers John. We need to see some nice pics of your Ur at times like this
    Here you go!
    And since I washed it yesterday
      • Dec 2017
      • 5992
        • Dec 2017
        • 5992
        After a break of about 10 days, I am back at it.
        Underneath is 80% cleaned off.
        • jbrentd
          • Dec 2009
          • 247
          Nice work Dave!
          newsh - that blue avant on boleros
          2001 A4 Avant QMS - FXK04'd
          1991 Audi CQ - Project
          1996 A4 12v Quattro Manual - SOLD
          • Lago Blue
            • Jul 2009
            • 843
            Thanks to all for the above discussion around the Koni install instructions etc., I'm going to add some of that into the Bilstein into MacP Strut thread, as at its root this addresses a shared threat with sensible alternate counter-measures. You may be interested to know I did find freeze/crush damage to one of my stock original Boge's which was so distorted, it was also difficult to remove from the strut. Having neither a drain-hole or oil-fill, the strut-tube had on its own become water-filled; of which, correct; didn't take much. My guess is it entered via the 6-sided opening in the OEM strut-tube cap-nut. Of course this wasn't apparent at the time, or fatal till winter and is interesting in that it is a little known variation on "Frozen Strut Syndrome" that in this case only (a conventional, sealed twin-tube type damper) does require freezing temperatures.
              • Dec 2017
              • 5992
              Windscreen removal did not go to plan.
              Someone had used panel bond inside the seal. It was never going to end well.
              • SteveH
                • 4460
                Unlucky! I bet they are hard to find with that blue sun strip
                91 Modded 3B
                14 A6 Avant Black Edition
                  • Dec 2017
                  • 5992
                  Trick of the light. It's green. Apparently available.
                    I nearly said a bad word then
                    Make sure the two drain holes under the seal in the bottom corners are open through to the scuttle.
                      • Dec 2017
                      • 5992
                      Thanks John. I will check those
                      • oldbiscuit
                        • Mar 2010
                        • 7
                        • Home: Hong Kong Current: Scotland
                        #146
                        [QUOTE=Tractor Dave;n2077287]The diff gets a good scrub.
                        The front ball joints got new rubbers.
                        [IMG]https://uploads.tapatalk-cdn.com/20200203/9a6875970970ed4f1865dc13935905de.jpg[/IMG
                        Hi Dave, I'm working on my 90 Quattro, had 2 new 19mm front ball Joint by wrong order, money been refunded, you can take it for free.
                          • Dec 2017
                          • 5992
                          [QUOTE=oldbiscuit;n2082958]
                          That is very kind of you. I have sent you a PM
                            • Dec 2017
                            • 5992
                            Off she goes for serious welding (no G)!
                            I was going to do it myself but I have to admit that some of it is beyond my skill level.
                            • tango123
                              • May 2017
                              • 892
                              oh my That must have took some work getting it on the truck
                                • Dec 2017
                                • 5992
                                Just rolled straight on no problem. The dolly has wheels.
