Mine is a 94 ABY with climate control and is R134a to,
and sorry for the hijack but on the subject,
mine was working fine and the day after the snowflake lights up and nothing, the compressor doesn´t start, the fan doesn´t start and no cold.
Looked at the fuses and relays on the fuse box and all normal, looked with a darklamp at night for major leaks and found no leaks at all.
I wasn´t using it for a while and first day I used it it was all normal, the day after it went kaput.
Normally when it´s low on R134a it still works but I charged last year and it worked fine the day before it stopped working, everything else its ok.
When I push the snowflake button it lights the snowflake on the panel but that is all.
Are there any fuses or relays under the dash I should check or do you guys have any idea of what could it be?
